Please Read This First:
Do not use this category for:
Question Posts lose formatting after editing
12 years 5 months ago #156516 by ninjastar
I found an issue. If I make a post and then I go back to re-edit, I lose all my paragraph spacing and have to add all the spacing again. Any idea?
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 512M | Max file upload: 128M
Joomla default template details : theme1339 | author: TemplateMonster.com | version: 2.5 | creationdate: Unknown
Kunena default template details : JF Social | author: JoomForest.com | version: 2.0 - k_3 | creationdate: 20.08.13
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Third-party components: UddeIM 3.2
Plugins: None
Modules: Kunena Latest 3.0.1 | Kunena Login 3.0.1
12 years 5 months ago #156536 by sozzled
These problems are caused by (a) the version of Kunena you have installed and (b) the Kunena template that you are using that was designed for a older version of Kunena.
I suggest you try the following things to resolve your current issues:
1) Upgrade to K 3.0.5
2) Use the K 3.0.5 Blue Eagle template
3) Discuss your problems with the developer of the JF Social template.
Good luck
The following user(s) said Thank You: ninjastar
12 years 5 months ago #156644 by ninjastar
Ok great. Thanks.
12 years 5 months ago #156912 by ninjastar
sozzled wrote: These problems are caused by (a) the version of Kunena you have installed and (b) the Kunena template that you are using that was designed for a older version of Kunena.
Good luck
Well I finally had time to do all this and nothing changes.
12 years 5 months ago #156926 by sozzled
What did the guys who designed your Kunena template suggest?
12 years 4 months ago - 12 years 4 months ago #157549 by ninjastar
This is still going on. I've tried all the default templates that Joomla comes with. Updated everything.
Bought another template and post re-edits still lose formatting. I don't know what to do anymore.
Last edit: 12 years 4 months ago by ninjastar.
