Question Error-Mails produced by subscriptions
11 years 8 months ago - 11 years 8 months ago #162492 by jpgjpg
Joomla-Website www.seniorbern.ch with possibility of subscriptions for the user.
Config-Report / Options für subscriptions in Kunena-Config / Screenshot-1 attached.
Kunena 3.0.6
Since about 10 days the subscritions-tool is producing a mail without any mail-adress for every posting in the forum.
The storing of a posting in the forum itself is confirmed at the screen by message "Could not instantiate mail function" (like in screenshot-1).
The mail sended by subscription-tool seems to have no mail-adress, because the response of the mailer-deamon is
The following addresses had permanent fatal errors
undisclosed-recipients:;
Transcript of session follows
553 5.1.3 undisclosed-recipients:;... List:; syntax illegal for recipient addresses"
The attached mail at this error-mail is the normal announcing-mail produced by the subscription-tool.
When I put my own mail-adress in the last configuration-field of subscriptions-tool "sichtbarer E-Mail-Empfänger" I'll receive a subscribtion-mail for every posting in the forum, but no more error-mails. My role is master/responsible for the forum.
ConfigReport
htaccess: Missing | PHP environment: Max execution time: 180 seconds | Max execution memory: 128M | Max file upload: 32M
Joomla default template details : seniorbern | author: Kyle Ledbetter | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.6 | creationdate: 2014-07-28
Third-party components: UddeIM 3.4
Plugins: None
Modules: Kunena Latest 3.0.1
Last edit: 11 years 8 months ago by jpgjpg.
11 years 8 months ago #162514 by xillibit
You need to check your Joomla! mail settings, do-you have modified something recently in your settings ?
11 years 8 months ago #162516 by jpgjpg
no, no change made
11 years 8 months ago #162537 by ismael
I need support.
I have a problem for a while now and no way to repair it. The problem is the url that users are automatically subscribed sent to a topic. The url is not correct because it sends them to a part of the forum does not correspond with the thread which received the url.
Failure Example url:
Asunto del Mensaje : prova Aruba
Categoría : Usuarios Clínica
Publicado por : Anónimo
URL : www.cedesna.com/index.php?option=com_kun...d=366&Itemid=733
Mensaje :
prueba
Url correct:
www.cedesna.com/index.php?option=com_kun...d=4&id=62&Itemid=733
11 years 8 months ago #162538 by jpgjpg
Ismael, please open a new topic, the problems are not identical.
The following user(s) said Thank You: ismael
11 years 8 months ago #162615 by jpgjpg
may I expect any response ? or should I deactivate and forget the function "subscribing" ?
Time to create page: 0.156 seconds
