Question Increase maxium character limit to increase post size
11 years 10 months ago #161176 by Shimei
How do I increase the maximum allowed characters to increase the post length?
htaccess: Exists | PHP environment: Max execution time: 45 seconds | Max execution memory: 128M | Max file upload: 24M
Joomla default template details : rt_chimera | author: RocketTheme, LLC | version: 1.2 | creationdate: Unknown
Kunena default template details : RND Kascetic | author: Roundtheme | version: 1.2.0 | creationdate: 2014-07-30
Third-party components: UddeIM 3.4
Third-party SEF components: sh404sef 4.4.6.2271
Plugins: Search - Kunena Search 3.0.1 | Content - Kunena Discuss 3.0.1 | JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 2.0.3 | JomSocial - Kunena Groups 2.0.3
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Login 3.0.1
11 years 10 months ago #161179 by 810
backend - kunena - config - frontend - max length subject
11 years 10 months ago - 11 years 10 months ago #161181 by Shimei
Hi 810,
Isn't that only for the subject (post title) line? I was looking to increase the main body length to say around 10,000 characters.
I'm having an issue with long articles being posted that get cut off.
Last edit: 11 years 10 months ago by Shimei.
11 years 10 months ago #161185 by 810
if i remembered there is no max length in the message
10 years 6 months ago #175584 by only1russ
I too am having issues - (a year later)
I did not think there was a limitation, but when I post a long article I get a "forbidden" notification.
Where could this be coming from?
10 years 6 months ago #175589 by 810
This has been fixed on K4.0
Else you need to run:
ALTER TABLE `#__kunena_messages_text` CHANGE COLUMN `message` `message` mediumtext NOT NULL;
The following user(s) said Thank You: only1russ
Time to create page: 0.151 seconds
