Question Error: "File does not exist"
12 years 1 month ago #159728 by leondelyon
Joomla v3.3.6, Kunena v3.0.6, JomSocial v3.2.1.4
got the following error messages in error.log of our apache server v 2.2:
components/com_kunena/template/blue_eagle/images/icons/online.gif
[Fri Oct 17 18:05:27 2014] [error] [client 195.14.0.179] File does not exist: xxx/components/com_kunena/template/blue_eagle/images/icons/offline.gif
[Fri Oct 17 18:05:27 2014] [error] [client 195.14.0.179] File does not exist: xxx/components/com_kunena/template/blue_eagle/images/icons/online.gif
[Fri Oct 17 18:05:27 2014] [error] [client 195.14.0.179] File does not exist: xxx/components/com_kunena/template/blue_eagle/images/icons/email.png
and also for components/com_kunena/template/blue_eagle/images/ranks
Of course thes files don't exist, are we supposed to have them
Did we miss something in the installation ?
Cheers,
L
12 years 1 month ago #159735 by xillibit
Thanks for the report, i have checked into Kunena files and the files that you have in your error log aren't present in kunena.
We need check why these files aren't presents or if these fiels needs to be added.
12 years 1 month ago #159740 by rich
Replied by rich on topic Error: "File does not exist"
hm.. I mean these images there were in the old versions Kunena 1.0 and Kunena 1.5.
This path is also out-of-date. Should be media/kunena/ranks
12 years 1 month ago #159741 by leondelyon
hi,
fyi, if it can help, it was a first installation, i mean not an upgrade from an older kunena version
cheers,
l
12 years 1 month ago - 12 years 1 month ago #159743 by sozzled
rich wrote: hm.. I mean these images there were in the old versions Kunena 1.0 and Kunena 1.5.
True—K 1.0 and K 1.5 both used GIF as the standard " category icon " image format—except that there was no Blue Eagle template in K 1.0.
leondelyon wrote: fyi, if it can help, it was a first installation, i mean not an upgrade from an older kunena version
The best way to help us to help you is to read the information that appears at the top of this page where we suggest you include your configuration report .
As rich mentioned, the pathname ../components/com_kunena/template/blue_eagle/images/ranks is wrong if you are using the Blue Eagle template for K 3.0; see Rank image folder .
My guess is that you are using an outdated template that does not work with K 3.0 and your configuration report will help us to know more.
Last edit: 12 years 1 month ago by sozzled.
12 years 1 month ago #159744 by leondelyon
OK, see below the report configuration:
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 1024M | Max file upload: 16M
Joomla default template details : Socialize | author: JomSocial | version: 1.2.8 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.6 | creationdate: 2014-07-28
Third-party components: Jomsocial 3.2.1.4
Third-party SEF components: sh404sef 4.4.4.1791
Plugins: Search - Kunena Search 3.0.1 | JomSocial - Kunena Groups 2.0.3
Cheers,
L
Time to create page: 0.154 seconds
