Solved Last posts displayed with delay [SOLVED]
11 years 9 months ago - 11 years 2 months ago #158802 by Kotsolis
The module latest posts doesn't work well.
Latest posts are displayed with a delay.
Look at the screenshot.
My forum is www.gameworld.gr/forum
I have to admit that I have caching enabled otherwise my server would go crazy with the high mysql load. But since I have caching enabled, then why this link works ok? " www.gameworld.gr/forum/newtopics "
Is caching only for modules?
Also, in my frontpage, the topic refresh and the comments refresh for JComments works fine. So I think that it is not a caching issue. It has to do with the module itself.
Can I put the "New topics" module (the bottom that you see in the screenshot) in the place of the "Last 10 posts" module?
Last edit: 11 years 2 months ago by Kotsolis.
11 years 8 months ago #158867 by xillibit
Where do-you have caching enabled in Joomla! configuration panel and/or in modules settings too ?
11 years 6 months ago - 11 years 2 months ago #160330 by Kotsolis
Ah sorry I had caching in Module Manager for 180 minutes. And now I've set it to 15.
So thank you.
Time to create page: 0.247 seconds
