Question Moderation
12 years 4 months ago #157172 by rlstephens
Moderation was created by rlstephens
Sorry if this is answered somewhere, I looked everywhere and couldnt find an answer...
I have a "For Sale" category that is set to no moderation. Some users are able to post, others require moderator approval. I have no moderators on that category, but I do have 2 global moderators...
Any idea why it could be happening?
Configuration:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 5M
Joomla default template details : gmarcmain | author: | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.2 | creationdate: 2013-08-18
Third-party components: CommunityBuilder 1.9.1
Plugins: None
12 years 4 months ago #157187 by rich
Replied by rich on topic Moderation
Please upgrade your Joomla and Kunena first. Latest are Joomla 2.5.22 and Kunena 3.0.5. But create a backup before!
Then disable the Kunena Plugins:
Kunena - AlphaUserPoints Integration
Kunena - JomSocial Integration
Kunena - UddeIM Integration
And at the plugin Kunena - Community Builder Integration choose "Enable Access Control = No".
Change the link Forums in the top menu to "Menu Item Alias". www.kunena.org/docs/Kunena_menu_issues
144 Forums topmenu view=home&defaultmenu=133
Then test, whether everything works correctly.
12 years 4 months ago #157221 by rlstephens
Replied by rlstephens on topic Moderation
Done. Will let you know if this helps...
Robert
12 years 4 months ago #157822 by rlstephens
Still requiring moderation...???
Updated configs:
Plugins: None
12 years 4 months ago #157824 by sozzled
Replied by sozzled on topic Moderation
The key to solving this mystery lie in what you wrote at the beginning:
rlstephens wrote: I have a ... category that is set to no moderation. Some users are able to post, others require moderator approval.
The key to solving the mystery is to identify what is different to those users who can post without requiring moderator approval compared with those who do require moderator approval.
I see that you are using Community Builder. This could be part of the reason but may not have any bearing on the issue at all. The first thing that I would do would be to look at how you have set up the access to the category. The second thing that I would do is to change the forum integration plugin settings to the values shown in red below:
Kunena - Community Builder Enabled: access=0 login=1 activity=0 avatar=1 profile=1 private=1
Kunena - UddeIM Disabled
Also, unless you purchased and separately installed the Community Builder PM feature, the last setting in the Kunena - Community Builder plugin has no effect as far as I know.
12 years 4 months ago #157827 by rich
Here is a similar topic. The user also had the right settings and it did not work. Maybe it's the same problem.
www.kunena.org/forum/k-3-0-general-quest...al-for-all-the-posts
Time to create page: 0.175 seconds
