Question Visitors count
12 years 10 months ago #152759 by HanKortekaas
Visitors count was created by HanKortekaas
In the 'Who is on line' there is a count of all visitors. I had hoped this would have been solved in version 3.04 but apparently it is not. or is it due to one of my settings?
Thsx
Han
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 16M
Joomla default template details : atomic | author: Ron Severdia | version: 2.5.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.4 | creationdate: 2013-12-22
Kunena version detailed: Kunena 3.0.4 | 2013-12-22 [ Ukko ]
Plugins: None
Han
12 years 10 months ago #152762 by sozzled
Replied by sozzled on topic Visitors count
This has not been fixed.
The following user(s) said Thank You: HanKortekaas
12 years 10 months ago #152769 by HanKortekaas
Replied by HanKortekaas on topic Visitors count
Thanks for your quick response. Before I start raising new questions is there somewhere a buglisting?
Han
12 years 10 months ago - 12 years 10 months ago #152771 by sozzled
You could try searching GitHub.
To be honest with you, there have been dozens on topics/questions posted on this forum about the "incorrect" who-is-online figure. This problem goes back nearly 5 years. In 5 years there has not been a solution to this problem. You may be wondering why no-one has solved this problem in 5 years. To be honest with you, I don't know why that is the case, either.
Every time this question arises, the "technical" reason given is that "it's a bug in Joomla". Well, that may be true!
If anyone knows how to fix the problem then I am sure that there would be a lot of happier people in the Kunena community. I don't know how to fix this problem. I'm just a user like you, HanKortekaas.
So, as an open request to the thousands of people who have joined the Kunena community, does anyone know how to fix Joomla to "fix" this problem? :whistle:
Last edit: 12 years 10 months ago by sozzled.
12 years 10 months ago - 12 years 10 months ago #152780 by HanKortekaas
Did anyone from the Kunena technnical team ever posted this to the Joomla technical team. I just can't see that the Joomla developers ignores this bug for as many as 5 years. To me it is more a question of which field should be read.
More-over, iff the Kunena team know about the problem than why include this item in the 'Who is online'
Han
Last edit: 12 years 10 months ago by HanKortekaas. Reason: add a commen
12 years 10 months ago - 12 years 10 months ago #152781 by sozzled
HanKortekaas wrote: Did anyone from the Kunena technnical team ever posted this to the Joomla technical team. I just can't see that the Joomla developers ignores this bug for as many as 5 years. To me it is more a question of which field should be read.
yes, the developers look at this forum - perhaps not as regularly as some of the moderators (like me) do - but that's only your opinion that they are ignoring this issue. If it was as easy as reading a field, which field is the one to be read?
As I've written many times before in reply to this question, the solution requires a technical understanding of Joomla internals - an understanding that is (a) beyond my level of expertise and (b) not something that I am personally interested in researching to discover the answer.
Let me repeat, for the record: Matias - the lead developer of Kunena - wrote (2 years ago):
Those numbers code from Joomla 1.5 -- code is mostly stolen from their Who is online plugin. :) The issue with Joomla is that it thinks that every guest who has been online in the past ~24 hours are online. It also thinks that every visit from bots (like Google) is one visitor more. So if Google has visited 1000 pages, you have 1000 guests.
We can fix 24h limit (actually it's a configuration option in Kunena), but we cannot fix Joomla from saving each bot visit as one extra user. For that you need to have plugin, which saves some extra information from the user into database.
Perhaps this information is hopelessly wrong, or out-of-date, I'm not sure. I haven't talked with Matias about this for over 2 years - the issue has not been as important to fix as it has been to produce K 2.0 and K 3.0 and to continue to work on K 3.1. That's just telling you what I know.
You could ask Matias about this personally. Whether he will answer you, I can't say. He's pretty busy at the moment.
And, I agree with you. If the information is inaccurate, why include it? Well, if it's not important, why not disable the feature and then you can relax. ;)
Time to create page: 0.159 seconds
