Question SQL error posting a test message on my forum
12 years 10 months ago #151994 by markstf
Hi there,
it's me again. Thanks to your help, I've fixed all the formatting issues but testing the forum, but if I try to post a messagge (object "test", message body the same "test"), I get the following error:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ' 'test')' at line 1 SQL=INSERT INTO jos25_kunena_messages_text (mesid, message) VALUES (, 'test')
It seems that there is not associated value to the "mesid" (index?) field.
Any idea?
Thank you,
Marco
12 years 10 months ago #152003 by xillibit
Can-you put here your Kunena report configuration settings please ?
12 years 5 months ago #156966 by ponyack
I am having this problem right now here is my config report -
website url clubdevo.com/index.php/new-forum
Database collation check: j25_kunena_categories have wrong collation of type latin1_swedish_ci on field alias j25_kunena_categories have wrong collation of type latin1_swedish_ci on field accesstype j25_kunena_categories have wrong collation of type latin1_swedish_ci on field channels j25_kunena_categories have wrong collation of type latin1_swedish_ci on field topic_ordering j25_kunena_categories have wrong collation of type latin1_swedish_ci on field params j25_kunena_messages have wrong collation of type latin1_swedish_ci on field ip j25_kunena_users have wrong collation of type latin1_swedish_ci on field view j25_kunena_users have wrong collation of type latin1_swedish_ci on field avatar j25_kunena_users have wrong collation of type latin1_swedish_ci on field icq j25_kunena_users have wrong collation of type latin1_swedish_ci on field aim j25_kunena_users have wrong collation of type latin1_swedish_ci on field yim j25_kunena_users have wrong collation of type latin1_swedish_ci on field msn j25_kunena_users have wrong collation of type latin1_swedish_ci on field skype j25_kunena_users have wrong collation of type latin1_swedish_ci on field twitter j25_kunena_users have wrong collation of type latin1_swedish_ci on field facebook j25_kunena_users have wrong collation of type latin1_swedish_ci on field gtalk j25_kunena_users have wrong collation of type latin1_swedish_ci on field myspace j25_kunena_users have wrong collation of type latin1_swedish_ci on field linkedin j25_kunena_users have wrong collation of type latin1_swedish_ci on field delicious j25_kunena_users have wrong collation of type latin1_swedish_ci on field friendfeed j25_kunena_users have wrong collation of type latin1_swedish_ci on field digg j25_kunena_users have wrong collation of type latin1_swedish_ci on field blogspot j25_kunena_users have wrong collation of type latin1_swedish_ci on field flickr j25_kunena_users have wrong collation of type latin1_swedish_ci on field bebo
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 64M | Max file upload: 16M
Joomla default template details : clubdevo_theme | author: Andy Miller | version: 1.0.2 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.4 | creationdate: 2013-12-22
Kunena version detailed: Kunena 3.0.4 | 2013-12-22 [ Ukko ]
Plugins: None
12 years 5 months ago #156971 by sozzled
@ponyack: Where do I start?
  • The wrong collation type used in the database tables?
  • The broken Joomla menu?
  • The conflicting forum integration plugin settings?
  • The outdated version of Joomla?
  • ... or the outdated and unsupported version of Kunena that you're using?
I think you have a few items that you need to attend to.
12 years 5 months ago #156972 by ponyack
So would you say its best to update the version of Kunena? and then see if I still have errors?
12 years 5 months ago #156973 by sozzled
I would say that the first thing you should do is update Joomla, then disable the forum integration plugins that you do not need, then fix up your database tables and use the same collation type, then trash and burn your Joomla menu and use the standard Kunena menu and then upgrade to K 3.0.5 and then see if you have any problems after you've done all of those things.
