Solved "Forum is down for maintenance" issues
11 years 5 months ago - 11 years 2 months ago #161053 by Kotsolis
I get this message today:
Check back soon!
Look here -> www.gameworld.gr/forum
I didn't change any files! Is this really a maintenance from your own side? And how long does it last? It's the first time I wake up early and I already see it for half an hour! There might be an issue here or hacking attempt, whatever!
I need immediate solution because people need to vote in a contest that is running!
Also this poll has dozens of pages (they might be over 50 pages of posts) and I hope that there is no mysql error due to Kunena!
Report Configuration
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '-08-2014' at line 1 SQL=SHOW FULL FIELDS FROM jos_kunena_messages29-08-2014
Database collation check:
htaccess: Exists | PHP environment: Max execution time: 72000 seconds | Max execution memory: 2048M | Max file upload: 1024M
Joomla default template details : whiteboard | author: Opensource | version: 2.6 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.6 | creationdate: 2014-07-28
Third-party components: Jomsocial 3.2.1.4
Plugins: Search - Kunena Search 3.0.1 | JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 2.0.3 | JomSocial - Kunena Groups 2.0.3
Modules: Kunena Latest 3.0.1 | Kunena Search 3.0.1
Edit: Forum is back online. I changed session from 3600 seconds to 1800 and cache time from 3 minutes to 5 minutes.
Question: How can I configure the forum maintenance to be scheduled in the day/hour that I want?
Thank you.
Last edit: 11 years 2 months ago by Kotsolis.
11 years 5 months ago - 11 years 5 months ago #161062 by xillibit
The forum goes in maintenance mode when you try to install a new version and it's fails.
Untill this issue is solved the forum stays in maintenance mode.
You see the following SQL error when you are in the page to generate configuration report ?
Last edit: 11 years 5 months ago by xillibit.
11 years 2 months ago - 11 years 2 months ago #162738 by Kotsolis
"Forum is down for maintenance" again.
I don't have the latest version. But I didn't have the latest version for weeks! So why is the component insisting to install the new version by making me lose my patience?
Look at those errors!
How can I solve them and how can I disable maintenance. I want the maintenance to happen only Sunday early morning 03:00 local time. Once per week! Nothing else! We have 12 o clock in the afternoon and Iam losing viewers right now which try to access the forum!
So give me exact instructions on how to set it once per week at the above hour.
Thanks.
ps. That is the error:
11 years 2 months ago - 11 years 2 months ago #162786 by xillibit
You need to check the permissions under /joomla/cache because Joomla! can't write in it
The query is incorrect it should be SHOW FULL FIELDS FROM jos_kunena_messages
Check that you have under plugin - system the plugin Kunena right installed and enabled
Forum goes in maintenance mode if something is broken into Kunena or if you are installing/updating Kunena
Last edit: 11 years 2 months ago by xillibit.
11 years 2 months ago #162877 by Kotsolis
Ok, I have lots of questions:
1)The "Forum is down for maintenance" and all those errors dissapear only when I purge cache through SSH. So that is the issue. You are saying that I should give 775 permissions to all folders under /cache ? Or even 777 ? Before the permissions were 755 and now I did it 775. Would that be ok?
2)Why does the maintenance cause issues to JComments? Comments temporarily dissapear from all articles while noone can leave a comment. Why are those connected to each other?
3)My hard disk was out of space when I found those errors today. Do you think that this is related somehow with the maintenance not going on?
4)Am I required to upgrade to the latest version? Does "Forum is down for maintenance" appear more often so that I will have to upgrade?
Please reply in numbers.
OFF-TOPIC: Also I wait for a reply HERE for weeks !
11 years 2 months ago #162878 by xillibit
1°) The permissions set to 775 are ok, you need to check too that the owner of cache directory is right the server apache to let Joomla! to be able to write by himself in cache directory
2°) There are nothing related to JComments and Kunena, i don't see what thing can cause that
3°) If you hard disk is full, you can't save new data int database, you need to have empty space else you will into issues. You need to check mysqll and apache to see what it say maybe you will discover some issues.
4°) During the upgrade process the "Forum is down for maintenance" will appear
Your site is hosted by a hoster or locally ?
Time to create page: 0.286 seconds
