Kunena 7.0.8 Released
Solved Forum menu not shown when following "recent post" module link
11 years 8 months ago - 11 years 8 months ago #161048 by jgkiefer
Joomla 3+
I have the recent post module on the site home page. When following a link form that module the forum menu does not appear in the forums. How do I fix this?
Here is the link
sethforums.com
Last edit: 11 years 8 months ago by 810.
11 years 8 months ago #161049 by 810
try:
backend - kunena - tools - menu manager - restore menu.
also check that sef settings are enabled, on joomla config, and on kunena config.
and make sure you have a .htaccess your root dir.
11 years 8 months ago #161050 by rich
This error occurs when kunena menu items are used in other menus. Links of other menus, which are linked to the forum, must be menu type "Menu Item Alias".
Here you will find the solution: www.kunena.org/docs/Kunena_menu_issues
11 years 8 months ago #161055 by jgkiefer
I have now discovered this error
Error 1062
Duplicate entry '62-8101' for key 'user_topic_id' SQL=UPDATE `j25_kunena_user_read` SET `topic_id`='8101',`category_id`='2',`message_id`='10657',`time`='1419526647' WHERE user_id='62'
Some single posts work and multiple threads create error.
11 years 8 months ago #161056 by rich
Please create a configuration report.
11 years 8 months ago - 11 years 8 months ago #161057 by jgkiefer
Thanks for helping with this.
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 192M | Max file upload: 100M
Joomla default template details : rt_hadron | author: RocketTheme, LLC | version: 1.3 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.0 | creationdate: 2013-05-15
Third-party components: UddeIM 3.5
Plugins: Search - Kunena Search 3.0.0 | Content - Kunena Discuss 2.0.4
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Login 3.0.1 | Kunena Search 3.0.1
Last edit: 11 years 8 months ago by rich. Reason: Configuration report correctly inserted
