Solved CAPTCHA incorrectly shown?
11 years 11 months ago #159616 by MatthijsWink
Hi have a question. In my forum, I have set CAPTCHA Challenge for users : 0
This should means when a registered user answers to a post, no captcha is used.
However, for a specific user Captcha is shown (but for other users not).
What triggers this ?
thanks for any help!
11 years 11 months ago #159617 by MatthijsWink
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 256M | Max file upload: 20M
Joomla default template details : yoo_moreno | author: YOOtheme | version: 1.0.6 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.6 | creationdate: 2014-07-28
Third-party components: CommunityBuilder 1.9.1
Plugins: None
Modules: Kunena Latest 3.0.1
11 years 11 months ago #159620 by 810
Replied by 810 on topic CAPTCHA incorrectly shown?
that's strange, try to sync users, I don't think it will work, but we can try it.
backend - kunena - tools -sync users - select all users - click on sync
11 years 11 months ago #159623 by sozzled
Replied by sozzled on topic CAPTCHA incorrectly shown?
You have this configuration setting:
Configuration » Security » Security Settings » Allow Guests to Post/Write = Yes
I also see that you have the settings
Configuration » Security » Security Settings » CAPTCHA Challenge for Guests = No
Configuration » Security » Security Settings » CAPTCHA Challenge for Users = 0
I agree with 810: I also think this is strange. Theoretically there should be no CAPTCHA challenge for guests or registered users. Perhaps using the Synchronising users feature will work.
11 years 11 months ago #159634 by MatthijsWink
Hi thanks for your replies.
I did the Sync -> but no results!
I still have a specific user that gets Catchpa and other users that don't ...
any other suggestions ?
thanks!
11 years 11 months ago #159669 by MatthijsWink
just noticed that for the user that gets the Catchpa, I also need to conform posts.
While for regular registered users, this is not necessary. So looks like there is something special with this user ...
Time to create page: 0.268 seconds
