Solved Problem : user having mutiple group can't write any topic
12 years 1 month ago #158115 by xpoint
I have the problem of group permission.
For example,
User AAA - Registered only
User BBB - Registered and Super User
User CCC - Super User only
User AAA can read and write all topic.
User BBB and CCC can't write new topic and reply topic.
When they try to click "submit" button, the color of information area in Boardcode change from yellow to red.
I had checked all category permission of category manager. I think that they are no problem.
Would you please advise me why user having multiple group can't write any topic?
Thank you and Best Regards
Configuration Report is here:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 20M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.6 | creationdate: 2014-07-28
Third-party components: CommunityBuilder 1.9.1
Plugins: Search - Kunena Search 3.0.1 | Content - Kunena Discuss 3.0.1
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Login 3.0.1 | Kunena Search 3.0.1
12 years 1 month ago #158157 by Matias
I don't think that the issue is the permissions, but something in JavaScript. If it was permission issue, you couldn't even enter to the editor screen.
Red border color means that the field is empty and the field is required. So basically writing some content into the red bordered area should fix the issue -- or something is broken in JS.
12 years 1 month ago #158160 by xpoint
Thank you for your comment.
I haven't change any CSS and javascript...
How can I analysis it?
12 years 1 month ago #158163 by xpoint
I tried debug mode of Firefox.
This Console said "document.id(...) is null" in newtopic.html:385
This line is;
function kunenaCheckPollallowed(catid) {
if ( pollcategoriesid[catid] !== undefined ) {
document.id('kbbcode-poll-button').setStyle('display');
} else {
document.id('kbbcode-poll-button').setStyle('display','none');
What does this line mean?
12 years 1 month ago #158164 by Matias
Umm.. Help row is changed to RED? Wow. I have no idea what could cause that to happen -- have you checked the HTML markup for the element if it tries to make it required?
You said this only happens to some users? If that's true, you have probably some plugin which has been enabled only for those users and it's causing these issues..?
12 years 1 month ago #158165 by xpoint
Yes. When "submit" Button is pressed, the Help row change from yellow to red.
According to console of firefox,
1) Warinig: not recommend get AttributeNode(), change to use getAttribute() in mootools-core.js:108
2) TypeError: document.id(...) is null in newtopic.html : 385
User having Registered group only can submit topic.
User having another of Registered can't submit topic.
Installed plugins are;
Community Builder
DPCalendar
JCE Editor
Community builder is wrong? I guess that this issue happen after installing Community Builder.
Time to create page: 0.273 seconds
