- Thank you received: 3
Solved Poll Answer - Length
- perryworld
- Senior Member
12 years 2 months ago #157154
by perryworld
Poll Answer - Length was created by perryworld
We are using Kunena 3.0 and have just tried to add a poll but are having a problem as the length of the answers are restricted to 25 characters.
Is it possible to increase the length of the answers and if there is what would we need to do.
Cheers
Rich
Cheers
Rich
- perryworld
- Senior Member
12 years 2 months ago #157169
by perryworld
Replied by perryworld on topic Poll Answer - Length
Hi All,
Any one got any ideas how we can achieve this
12 years 2 months ago #157171
by xillibit
Replied by xillibit on topic Poll Answer - Length
You can look in the template and increase the value of length for input fields for options of poll
- perryworld
- Senior Member
12 years 2 months ago #157181
by perryworld
Thanks for the reply, Do you know which file this will be in - is it in the administration folder or in the component.
We are on Kunena 3.0.5 and are using the blue eagle template.
Rich
Rich
12 years 2 months ago #157190
by xillibit
Open the file /media/kunena/js/poll.js and change at line 22 the maxlength by something more higher
The following user(s) said Thank You: perryworld
- perryworld
- Senior Member
12 years 2 months ago #157226
by perryworld
Thanks xillibit
That solved the problem
Cheers
Rich
Cheers
Rich
Time to create page: 0.236 seconds
