Solved Сut large topics into smaller. Works for me only once.
12 years 6 months ago - 12 years 6 months ago #150982 by mecenat
Hi
I want to cut big topic with 5000 posts into few smaller ones. :woohoo:
The problem is, when i cut topic first time, i pick some post, click moderation, and i have an option there, to cut topic from that post. So i create new topic, where this post is main one.
But when i go into the new, just created topic (created from other topic with that option) - i dont have this option any more, i mean option to cut it again and move picked post and posts after it to new topic...
So is it not possible to cut topic as many times as needed? I can not move posts one by one :whistle: Is it a bug or wanted thing? :unsure:
Last edit: 12 years 6 months ago by mecenat.
12 years 6 months ago #151031 by xillibit
It's possible to cut topics as many times that you want
Can-you put here your Kunena report configuration settings ?
The following user(s) said Thank You: mecenat
12 years 6 months ago - 12 years 6 months ago #151038 by mecenat
htaccess: Exists | PHP environment: Max execution time: 600 seconds | Max execution memory: 1000M | Max file upload: 600M
Joomla default template details : gk_msocial | author: GavickPro | version: 3.9 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.3 | creationdate: 2013-10-20
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Plugins: None
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Login 3.0.1
12 years 6 months ago #151039 by Mortti
In What information should I include when I ask for help (including how to post my configuration report)? is also:
Please do not edit that report. By including your original, unedited configuration report you will save your time and our time in answering your questions.
12 years 6 months ago - 12 years 6 months ago #151041 by rich
If I have understood your question correctly, then it is a lot of work. You can work only backward from the last post.
Go into the configuration and set the history limit higher, then you have more overview (Configuration > Frontend > History Limit).
Start with the last post and check the messages backward.
Example:
Messages from 5000 - 4050 belong together, then moderate message 4050.
"Move selected message and all 49 messages posted after it" (and so on)
Last edit: 12 years 6 months ago by rich.
12 years 6 months ago #151042 by mecenat
rich wrote: If I have understood your question correctly, then it is a lot of work. You can work only backward from the last post.
Example:
Backward. Thank you brother. This is works) Quite hard to do this in backward way but i can manage)
Time to create page: 0.276 seconds
