Solved Having problems restricting the right to post within a category
13 years 4 months ago #145836 by WhatNoWebsite
Hi
I've set up a separate user group in Joomla called "Subscribers" which takes it's permissions from "Registered".
I've adjusted the settings in a category within Kunena to use the Joomla access levels so that only "Subscribers" can post but this does not appear to be working as a registered user can indeed start a new topic.
13 years 4 months ago #145837 by WhatNoWebsite
Configuration Report:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 10M
Joomla default template details : jsn_epic_free | author: JoomlaShine.com | version: 5.1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.1 | creationdate: 2013-06-29
Kunena version detailed: Kunena 3.0.1 | 2013-06-29 [ Noordwijkerhout ]
Plugins: None
13 years 4 months ago #145980 by WhatNoWebsite
I've waited patiently for a response.
Is anyone at Kunena available to look at this...?
13 years 4 months ago #145990 by sozzled
Thank you for your patience. I, personally, do not understand why things are not working as they should according to the picture of how you've defined access to the forum category you showed us in your picture; unless, perhaps, you've made some changes to the component access? Have you, in any way, modified permissions to Kunena component?
13 years 4 months ago #145993 by WhatNoWebsite
No, that's what's confusing me.
I added a user level called "Subscriber" so that I can control which forum categories this user type can access but when I apply this in the back end it does not work in the front end.
Strange I know...
13 years 4 months ago #146009 by sozzled
We've bounced this topic among the team and we're as puzzled as you are. :S
Time to create page: 0.156 seconds
