This category is for discussing issues with the K 3.0 Blue Eagle template.
Question changing default colors
11 years 7 months ago #164307 by squeak251
I am trying to change the default colors on Blue Eagle.
I have changed the parameters, but it is still showing the default colors. Do I have to change the color manually in the css? If I do, which CSS file is it?
11 years 6 months ago #164392 by 810
Replied by 810 on topic changing default colors
you need to change it on the -min css files.
Or you can turn debug on. on the kunena configuration
11 years 6 months ago - 11 years 6 months ago #164394 by sozzled
Replied by sozzled on topic changing default colors
squeak251 wrote: I am trying to change the default colors on Blue Eagle.
Hi there. I am not sure that I totally understand the question. When you wrote that you "changed the parameters", which parameters (in the Kunena Template Manager) did you change and what value(s) did you change them to? I remember that there was a problem with the Kunena Template Manager in an older version of Kunena—trying to store certain named values—so it may help to know which version of Kunena we are discussing.
810 wrote: You need to change it on the -min css files ...
Are you saying that the Kunena Template Manager for K 3.0.8 does not allow you to change the default colour parameters for the Blue Eagle template? :ohmy:
Last edit: 11 years 6 months ago by sozzled.
11 years 6 months ago #164395 by squeak251
Replied by squeak251 on topic changing default colors
Yeah, I changed the parameters in the template manager, but the colors stayed the same on the site.
I will edit the template tomorrow, but wish the parameters would work. The parameters file has been changed, just not coming through.
11 years 6 months ago - 11 years 6 months ago #164396 by sozzled
squeak251 wrote: Yeah, I changed the parameters in the template manager, but the colors stayed the same on the site. I ... wish the parameters would work. The parameters file has been changed, just not coming through.
Which parameters did you change? Perhaps the colours have not changed if your website is cached. It may be an idea to clear the site cache (and possibly your browser cache, too).
Also, which version of Kunena are you using? If this is an issue with the current version of Kunena then I am sure that the whole community needs to know about it. If the current version of Kunena Template Manager does not honour the parameter changes then there is a major problem here.
Your configuration report may help the forum moderators and developers learn more about your problem.
11 years 6 months ago #164450 by squeak251
from the component page on the Joomla Admin side, I go to the template, then parameters.
I am using 3.0.8
My config is:
htaccess: Exists | PHP environment: Max execution time: 180 seconds | Max execution memory: 256M | Max file upload: 256M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.8 | creationdate: 2015-04-05
Kunena version detailed: Kunena 3.0.8 | 2015-04-05 [ Imperium ]
Plugins: None
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1
