This category is for discussing issues with the K 3.0 Blue Eagle template.
Question responsive problem on iPad
11 years 7 months ago #163115 by tonvermaas
Joomla! SEF: Enabled | Joomla! SEF rewrite: Disabled | FTP layer: Enabled |
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 50M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.7 | creationdate: 2015-02-01
Kunena version detailed: Kunena 3.0.7 | 2015-02-01 [ Galah ]
Third-party components: CommunityBuilder 2.0.7
Plugins: None
11 years 7 months ago #163119 by 810
Replied by 810 on topic responsive problem on iPad
what is your issue?
11 years 7 months ago #163120 by tonvermaas
Part of the forum layout is truncated at the right side.
(see picture)
11 years 7 months ago #163121 by 810
could you create a user for me, then i will check the issue.
11 years 7 months ago - 11 years 7 months ago #163122 by tonvermaas
user: Guest01
pw: xxxxxxxxxx
The problem is not only on the iPad. On PC aswell.
Last edit: 11 years 7 months ago by tonvermaas.
11 years 7 months ago #163123 by 810
You should add "visible-desktop" without the quotes on the right modules, add the text on class with space before it.
