Question Kunena 2.0.1 issues with Community Builder
14 years 3 months ago - 14 years 3 months ago #131939 by ncwebpros
Installed Kunena 2.0.1 on Joomla 2.5.6 site using Community Builder 1.8.1. It seemed to install fine - it went through the installation steps and I clicked "finish" to finish the installation. I went into the Kunena Configuration and actived the Community Builder plug-in. I went to the site and tried to login and when I do, I get a blank white screen. Then I go back into the backend and click on Kunena to try to go back into the configs to see if I missed something and I get the following error:
Fatal Error was detected!
Fatal Error: Class 'Kunena' not found in components/com_comprofiler/plugin/user/plug_cbforums/cbforums.class.php on line 33
The error was detected in the Comprofiler Component.
I found a similar topic on here and uploaded a hot fix . . didn't help. I tried went into Community Builder and click on CB Forms to see the settings there, but I get a white screen there as well. . . Any suggestions?
Last edit: 14 years 3 months ago by ncwebpros. Reason: Added additional info
The topic has been locked.
14 years 2 days ago #137162 by goranbaxy
I have same problem :(
14 years 2 days ago #137166 by 810
Please try CB 1.9
14 years 2 days ago #137167 by goranbaxy
I have cb 1.9
14 years 2 days ago #137168 by 810
Your issue is a configuration problem or bad upgrade of Kunena. Class exist checks are covering the entire plugin to prevent this. Line 33 doesn't call the class Kunena either so you could be using an out of date release of CB Forums (latest is 2.1.4).
14 years 2 days ago #137169 by goranbaxy
I use last version of CB and last ver. of kunena. How can I see what ver. of CB forums I use? and where can I download last version?
Thanks alot
