Question nts_kcarbon template: Sidebar Usernames color is same
14 years 2 months ago - 14 years 2 months ago #118420 by enforcer31
Kunena 1.7.2, CB 1.7.1
hello,
the name/username color at the sidebar are all red.
members and admins got a red color.
how can i fix that?
Last edit: 14 years 2 months ago by enforcer31.
14 years 2 months ago #118448 by sozzled
There are several reasons for this happening. It could be your Joomla site template. It could be your Kunena template. It could be because of what user group your users are located.
We do not know anything about your website (apart from the images you showed). Your configuration report would help.
Does the issue occur if you use one of the standard/default templates for Joomla? Does the issue occur if you use the default Blue Eagle template for Kunena? When your users register at your site, what Joomla user group are they registered into?
14 years 2 months ago - 14 years 2 months ago #118478 by enforcer31
hello,
the problem is at every template.
just the usernamecolors switch to green or blue at other joomla templates then.
i tested changing joomla template and kunena template both....still same problem.
ive seen the the class
#Kunena .kwho-admin, #Kunena a.kwho-admin
given to every user.
i think the usergroups are right...normal users are in registred users, admins are at admins..etc.
i just see inside joomla sometimes if a new user is online, his color is for a short time period diffrent than the normal blue color.
after they pressed the activation link the are shown registed.
or what do you mean about the usergroups?
14 years 2 months ago #118484 by sozzled
If you have a problem with the nts_kcarbon template I suggest that you contact the author of that template.
*** Topic moved and renamed ***
14 years 2 months ago - 14 years 2 months ago #118487 by enforcer31
no..its not a problem of this template.
this error is at every template..like i said.
add:
this problem is caused by cb forum integration....
i found it!
hopefully can be fixed
14 years 2 months ago #119344 by 9themestore
Hi enforcer31,
We can help you solve this problem. Contact with me, i'll guide you how to change it.
Thanks.
Time to create page: 0.292 seconds
