Question Kunena and the Jomsocial activity stream
15 years 2 months ago #99427 by jaymzyates
I upgraded jomsocial and I seem to have lost the ability for the jomsocial integration. Posts do not seem to updating the jomsocial activity stream, regardless of what I have set in the integrations tab (auto detect or jomsocial). Thoughts?
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 90M | Max file upload: 7M
Joomla default template details : rt_syndicate_j16 | author: RocketTheme, LLC | version: 1.6.0 | creationdate: April 29, 2011
Third-party components: Jomsocial 2.2.2
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Search 1.6.4 | My Kunena Forum Menu 1.6.4 | My Kunena Forum Posts 1.6.4 | Kunena Groups 1.6.4
Modules: Kunena Latest 1.6.4
15 years 2 months ago #99479 by jaymzyates
Would this be a question for Jomsocial support? I thought the integration was OOB with Kunena.
15 years 2 months ago #99506 by mstephan
Kunena handles the posts to the activity stream as far as I know.
Anyway, I'm having the same problem. I used jupgrade today to upgrade to Joomla 1.6.3 and then upgraded to Joomla 1.6.4, downloaded the latest Jomsocial and Kunenea coms and suddenly Kunena doesn't write to the feeds anymore?
I'll post my config as well.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 2M
Joomla default template details : ja_purity_ii | author: JoomlArt.com | version: 1.1.0 | creationdate: June 2011
15 years 2 months ago - 15 years 2 months ago #99507 by mstephan
jaymzyates, if you figure it through your own means or through Jomsocial could you post any updates here? I'm sure it would be helpful more more than just me.
Thanks.
Last edit: 15 years 2 months ago by mstephan.
15 years 2 months ago #99589 by Matias
We have been aware of this issue, but there are no solution to it, at least not yet.
Someone told that the latest JomSocial version has a bug in it's activity stream integration, but I don't know if it is true or not. Regardless of bug or no bug, I believe that we, too, have some issues in our code with user groups if you use JomSocial activity streams in Joomla 1.6.
15 years 2 months ago #99611 by jaymzyates
Thank you for responding! At least we aren't in the dark now.
I asked over at the JomSocial forums too.
Time to create page: 0.266 seconds
