- Thank you received: 1
Question Kunena and jAwards Integration
15 years 3 months ago #98210
by BoardBoss
Kunena and jAwards Integration was created by BoardBoss
Greetings all - I am posting in the general talk forum because I have searched these forums, and Googled many other sites, although I have thus far been unsuccessful in my quest for an answer to my question. I have found posts or sites that suggest that jAwards will integrate with Kunena with a hack; however, I cannot confirm that is with the latest versions.
My environment is Joomla 1.5.23, Kunena 1.6.4 and jAwards 1.1. I would appreciate an answer to he question: has anyone successfully integrated jAwards 1.1 into Kunena 1.6.4? If so, I would appreciate a reply with how, or a link to where this is detailed. Thanks in advance!
15 years 3 months ago #98221
by xillibit
Replied by xillibit on topic Re: Kunena and jAwards Integration
I never heard something about jawards integration into Kunena, but the jawards components hasn't been updated since a bit more than an year, so...
15 years 3 months ago #98257
by BoardBoss
Replied by BoardBoss on topic Re: Kunena and jAwards Integration
Thank you for the reply, xillibit. I understand what you mean about the last update for jAwards being very old; however, after reading this thread:
www.kunena.org/forum/9-extensions-module...ds?limit=10&start=20
it made me wonder.
15 years 3 months ago #98397
by legu
Replied by legu on topic Re: Kunena and jAwards Integration
humm, i dont think so...
15 years 3 months ago - 15 years 3 months ago #98497
by Lodder
Replied by Lodder on topic Re: Kunena and jAwards Integration
Yes it does work. I have tested it on my website blackpanthergaming.com using Kunena 1.6.4 and the latest version of Jawards. The coding I have used will show 10 medals probaby about 5 per line, depending on the width of the profile info. This is of course editable.
Put it in /components/com_kunena/template/default/view/profile.vertical.php on line 81 after:
<?php echo $this->profile->profileIcon('email'); ?>
</li>
</li>
<?php
// Hack for jAwards integration, displays some medals of the user for Kunena 1.6
$number_medals = 10; // number of medals to show
$query = "SELECT b.image, b.name"
. "\n FROM #__jawards_awards AS a"
. "\n LEFT JOIN #__jawards_medals AS b ON b.id = a.award"
. "\n WHERE a.userid=". $this->profile->userid
. "\n ORDER BY RAND() LIMIT ".$number_medals;
$database = &JFactory::getDbo();
$database->setQuery( $query );
$medals = $database->loadObjectList();
// URL links to the jAwards-Tab for Community Builder which displays all
// medals of the user - change to another URL of needed
$awards_url=JRoute::_('index.php?option=com_comprofiler&task=userProfile&user='.$this->profile->userid."&tab=getawardstab");
// CSS-class "ja_medals" allows individual styling of medal images and
// container. "nobr" keeps the medals from breaking apart, display them
// in one row.
$msg_jawards = "<div class=\"ja_medals\"><nobr>";
foreach ($medals as $med){
$msg_jawards.= "<a href=\"$awards_url\" title=\"$med->name\">"
. "<img style='border:0px;padding:0px;' src=\"".KUNENA_JLIVEURL."/images/medals/".$med->image ."\" alt=\"".$med->name."\" />"
. "</a>";
$msg_jawards.="</nobr></div>";
unset($medals);
echo $msg_jawards;
Last edit: 15 years 3 months ago by Lodder.
15 years 2 months ago #102864
by Lodder
also works with Kunena 1.6.5
Time to create page: 0.255 seconds
