Kunena 7.0.8 Released
Question AlphaUSerPoints Problem
15 years 2 months ago #97363 by pioneer6869
I have set the Configuration in Kunena [Latest version] to set the profiles to AlphaUserPoins and still nothing. Every time a user posts they get no points.
Any ideas?
Wholesale Drug Testing.Com
Management
www.wholesaledrugtesting.com
15 years 2 months ago #97386 by Mortti
Replied by Mortti on topic Re: AlphaUSerPoints Problem
I think the first we have to know what J! and AUP you are using...?
docs.kunena.org/index.php/K_1.6_Configuration_Report
15 years 2 months ago #97839 by pioneer6869
Kunena 1.6.4 and Alpha 1.6.1
Management
15 years 2 months ago #97994 by pioneer6869
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 1024M | Max file upload: 5M
Joomla default template details : submitco_forums_13 | author: Alex Athineos | version: 4.5 | creationdate: 2011-06-04
Third-party components: AlphaUserPoints: The file doesn't exist alphauserpoints.xml ! | CommunityBuilder: The file doesn't exist comprofilej.xml ! | UddeIm: The file doesn't exist uddeim.j15.xml !
Third-party SEF components: sh404sef: The file doesn't exist sh404sef.xml !
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Search 1.6.2 | Kunena Discuss 1.6.4
Modules: Kunena Latest 1.6.4 | Kunena Stats 1.6.2 | Kunena Login 1.6.4 | Kunena Search 1.6.4
Management
15 years 2 months ago #98005 by xillibit
Do you have published the right rules in AUP and set some points to these rules ?
I need to test if with AUP 1.6.1 something has changed
15 years 2 months ago #98006 by pioneer6869
yes i do...
Its funny, I got everything to work OTHER than Kunena. I did that by putting the AUP plugins first. then everything started working....
Except of course Kunena...
Check it out.. You dont have to register.
forums.submitco.com I have a quick login button.... Please have a look if you wish..
Management
Time to create page: 0.244 seconds
