Question Kunena 1.5.0a and Jomsocial
17 years 5 months ago #10662
by jokas
Kunena 1.5.0a and Jomsocial was created by jokas
Hi Guys,
just installed the new kunena 1.5.0a over my existing 1.0.8.
The installation works fine without errors, but after that my hole websites doenst came up - only a white site!
Any ideas how to get my joomla community running in native mode?
- johnnydement
- Elite Member
- Thank you received: 5
17 years 5 months ago #10670
by johnnydement
Replied by johnnydement on topic Re:Kunena 1.5.0a and Jomsocial
Hope as stated you're running on a test site, as stated, this is an alpha release for testing purposes, not to be used in production sites.
A white site means not everything went ok during install...
And white site in forums? or any other part?
17 years 5 months ago #10672
by core2
Visit the Kunena documantation .
Replied by core2 on topic Re:Kunena 1.5.0a and Jomsocial
First of all Kunena 1.5.0 alpha is not for use in production environment, I hope this is a test site?
Are talking about the frontpage of your site that is white or is it the kunena forum?
Which module/component do you have? Which template are you using?
Have you looked at the html code of the white page (ctrl+u in firefox)?
Have you checked the errorlogs of your server (php and apache)?
17 years 5 months ago #10707
by jokas
Replied by jokas on topic Re:Kunena 1.5.0a and Jomsocial
there was no html code at the white frontend site. backend was working fine - excepting kunena.
i was upload my backup again - no problem then, but it would be nice if the problem could be fixed soon.
17 years 5 months ago #10731
by core2
Alpha releases are for sorting out problem like this. But to solve the problem the developers need to find the source of the problem. Can you check your php log for errors related to the install.
On component should not break the hole joomla system except if you visit the component is self.
Do you have the Kunena on your frontpage? Do you use mod_kunena_latest or similar?
You mention joomsocial in the subject but didn't give more information about that.
17 years 5 months ago #10748
by jokas
i have no access to my php logs, maybe someone else with the same configuration can give more information.
in the meantime i will go further with 1.0.8.
Time to create page: 0.262 seconds
