Question Adding Thai language to Forum
administrator/components/com_kunena/language but there is no language folder! Am I supposed to create one or does it go elsewhere?
Frontend: language
regards 810
tonilaird wrote: I have downloaded kunena.thai.php file and I know I'm supposed to place it into this root:
First download and install Joomla! Thai language package for your site(what Joomla are you using?(1.5.xx/1.6.x))...
I used Google and I found this site where are links to Joomla! Thai languages: www.joomlacorner.com/ I found it here: forum.joomla.org/viewtopic.php?p=1175421...165c7244428#p1175421
Look like there is not very active action because of this:
th-TH_joomla_lang_full.1.5.15v1.zip for Joomla! 1.5.xx (latest released version of the Joomla! is 1.5.23)
th-TH joomla lang site 1.6.1 v1.zip (th-THjoomlalangsite1.6.1v1.zip) for Joomla! 1.6.x (latest released version of the Joomla! is 1.6.3)
If you use J! 1.5.23 you should try that first one... it should make th-TH folder in those:
Backend: administrator\language
Frontend: language
Something like this:
administrator/language/th-TH/
language/th-TH/
th-TH (Thai) language files are already done for the Kunena 1.6.4 and they are in Kunena installation package, but you have to install core Joomla! Thai language first... then re-install Kunena
Perhaps the Thai language files translator for Kunena get the ability to steer you to the updated Joomla! Thailand packages...
