Use this category:
Solved Menu missing
2 years 4 months ago #231736 by Bearsampp
Menu missing was created by Bearsampp
The menu is completely missing from the menu bar.  If I check there is a kunena menu and doing rebuild menu tool doesn't solve the issue.
All I see is a blank bar with the word "login"
2 years 4 months ago #231740 by Pinkeltje
2 years 4 months ago #231742 by Bearsampp
Replied by Bearsampp on topic Menu missing
I've done all of that several times.
bearsampp.com/forum is all I see
2 years 4 months ago #231744 by Pinkeltje
Replied by Pinkeltje on topic Menu missing
I suppose it is a css conflict either with your template or your custom.css
2 years 4 months ago #231745 by rubin4
Replied by rubin4 on topic Menu missing
I appears that I have the same problem.
I've been testing Kunena 6.3.2 with Joomla 5.1.1 (native template). Even if I used default Kunena Menu (in the Main Menu), when I access the forum page, I cannot see the Kunena menu items. However, if I login and click "Preferences", the Kunena menu shows up, and stays there. It appears that the Kunena menu items are not visible only when I "lend" on the forum.
Your help will be highly appreciated.
2 years 4 months ago #231746 by Bearsampp
It's not my custom.css  This is a clean install of kunena.  If you look at this image you'll see its mentioning an off canvas menu which is normally only for mobiles.  Furrthermore it mentions a menu toggle that doesn't appear either
