Question After update many errors in console
5 years 6 months ago #1 by tomsson
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 128M
Joomla default template details : shaper_helixultimate | author: JoomShaper.com | version: 1.0.4 | creationdate: Feb 2018
Kunena default template details : Crypsis | author: Kunena Team | version: 5.1.5 | creationdate: 2018-10-14
Kunena template params:
Kunena version detailed: Kunena 5.1.5 | 2018-10-14 [ Rhea ]
Third-party components: CommunityBuilder 2.2.1
Plugins: Search - Kunena Search 5.1.1
Modules: Kunena Latest 5.1.1
After update on the site ADD NEW POST is not working button \\add attachments\\, editor is looking strenge (no icons) or in the console I have many errors.
Can you help me with this ?
5 years 6 months ago #2 by rich
Please disable the script optimization (compression), then empty the cache and test your Forum again.
5 years 6 months ago #3 by micker
hello for me same error ....
i use helix 3 + jch
i disable JCH clear cache but same thing
5 years 6 months ago - 5 years 6 months ago #4 by tomsson
rich wrote: Please disable the script optimization (compression), then empty the cache and test your Forum again.
I disabled commpression in global configuration and empty cache but this was not helpfull.
still have problem
Last edit: 5 years 6 months ago by tomsson.
5 years 6 months ago #5 by micker
Same ...
4 years 1 month ago #6 by mbistato
I have got the same issue. Have you found any solution so far?
4 years 3 weeks ago - 4 years 3 weeks ago #7 by Seaol
Go to the screen where you are experiencing the error. In Chrome, navigate to View > Developer > JavaScript Console or More Tools > JavaScript Console or press Ctrl + Shift + J. The error console will open. If you don't see any errors try reloading the page.
______________________________________________________________________________________________________________________________________
PrepaidCardStatus Login
Last edit: 4 years 3 weeks ago by Seaol.
Time to create page: 0.564 seconds
