Solved Change Avatar
4 years 9 months ago #222029 by OldCharlie
Change Avatar was created by OldCharlie
How do I change the Avatar?   If I put in a photo for the avatar and want to delete or change it how is it done.  I can't find anything in forum or help.
4 years 9 months ago - 4 years 9 months ago #222031 by Leen
Replied by Leen on topic Change Avatar
login at the front of your kunena forum.
then click on the profile tab and then on the edit button.
in new image click on avatar image tab.
and you could go on with that.
it could still be that in the kunena configuration tab avatar you have to set the Default avatar type on image
my pictures are in dutch language sorry
With kind regards
Leen
Last edit: 4 years 9 months ago by Leen.
4 years 9 months ago #222041 by OldCharlie
Replied by OldCharlie on topic Change Avatar
Thanks for helping with trying to change my profile avatar.   Still can't here is a video of what I see:
billcory-pictures.s3.us-west-2.amazonaws...angeAvatarKunena.mp4
4 years 9 months ago #222042 by rich
Replied by rich on topic Change Avatar
In the backend, go to Kunena Dashboard -> Plugins and disable the Gravatar integration plugin. Then you can add or change your avatar in your profile in the frontend.
4 years 9 months ago - 4 years 9 months ago #222090 by OldCharlie
Thanks,,, I did as you say, but still can't change the Avatar.  Click to view my video:
Still can't change Avatar
Last edit: 4 years 9 months ago by OldCharlie.
4 years 9 months ago #222091 by Leen
Hi You forget that the Avatar change has to be done through the Frontside of Your website .
With kind regards
Leen
