Solved Kunema old version
5 years 3 weeks ago #219895 by pinius
Kunema old version was created by pinius
Hello Guys,
there is a way to donwload an old package about Kunena 1.5/1.6 to install in  an old joomla site 1.5.26?
Thanks a lot
Pin
5 years 3 weeks ago #219896 by Leen
Replied by Leen on topic Kunema old version
Joomla might be picked up here  joomla old
and kunena maybe pick up here  kunena old 1.5 and  kunena1.6
With kind regards
Leen
The following user(s) said Thank You: pinius
5 years 3 weeks ago #219903 by pinius
Replied by pinius on topic Kunema old version
Leen thanks for you answer.
I donwload the Zip, but i suppose that it's misses some files, because when i try to install  it gives me back an error:
  • Error! Could not find a Joomla! XML setup file in the package.
5 years 3 weeks ago #219906 by Leen
I was a bit afraid of that there in githup
I thought that installing would be something else, but it's been a long time since I tried that myself.
  which version did you try.
I found a kunena1.6 on my pc maybe that will help you
With kind regards
Leen
5 years 3 weeks ago - 5 years 3 weeks ago #219907 by pinius
Oh thanks you. I try it!!/media/kunena/emoticons/
Last edit: 5 years 3 weeks ago by pinius.
5 years 3 weeks ago - 5 years 3 weeks ago #219908 by Leen
mm I had just tested it myself in uniserver zero XI and XIV but don't think it works either.
Did some more searching and came up with this "com_kunena_v1.6.0_b3620_2010-10-03.zip"
I was able to install it via the extension manager  maybe that's enough for you too.
With kind regards
Leen
Last edit: 5 years 3 weeks ago by Leen.
