Solved Statistics in backend don´t work
7 years 10 months ago #207483 by zuz
I like to view the stats of our Forum at www.jaii.de But I get no datas in the Statistics. Enclosed please find a screenshot.
I used the tools "sync user" and "recount stats", but I get no stats. Any ideas how I can reset the statistic tool?
Thank you!
htaccess: Exists | PHP environment: Max execution time: 3600 seconds | Max execution memory: 1024M | Max file upload: 4096M
Joomla default template details : yoo_aurora | author: YOOtheme | version: 1.0.2 | creationdate: January 2015
Kunena default template details : Crypsis | author: Kunena Team | version: 5.1.8 | creationdate: 2018-12-30
Kunena template params:
Kunena version detailed: Kunena 5.1.8 | 2018-12-30 [ Janus ]
Third-party components: CommunityBuilder 2.4.0 | UddeIM 3.9
Plugins: Search - Kunena Search 5.0.3 | Content - Kunena Discuss 5.0.3
Modules: Kunena Latest 5.0.3 | Kunena Stats 5.1.1 | Kunena Search 5.0.3
7 years 10 months ago #207484 by Leen
does enable statistics in Administrator> components> kunena> Kunena: Configuration
tab extra and then at Statistics plugin settings.
ps.
And if I'm right, you only see statics at the front.
With kind regards
Leen
The following user(s) said Thank You: zuz
7 years 10 months ago #207485 by Leen
and if statistic is not shown on the front, it may be that it is only visible for logged in members to set this up at administrator> kunena> Kunena: Configuration tab security and then half roads approximately at Guests may see statistics yes or no
With kind regards
Leen
7 years 10 months ago #207488 by rich
@zuz
The statistics which you mean, show only moderator actions or actions such as delete, edit and so on... But you must enable it in the configuration (tab Users -> Define if you want to log action or moderation).
7 years 9 months ago - 7 years 9 months ago #207529 by zuz
Thank you all! All information helps me to get some facts about our forum.
Last edit: 7 years 9 months ago by zuz.
Time to create page: 0.167 seconds
