Solved Can not edit profile
8 years 10 months ago #1 by randwic
Can not edit profile was created by randwic
Hello , I just updated kunena 4.0, but when I try to edit my profile I have no choices . Unable to upload an avatar , you can not view topic monitoring, impossible to see the attachments . In fact there is nothing .
and all this with the new theme.
8 years 10 months ago #2 by 810
Replied by 810 on topic Can not edit profile
could you add your kunena report here.
8 years 10 months ago - 8 years 10 months ago #3 by randwic
Replied by randwic on topic Can not edit profile
Database collation check: jgjmr_kunena_pratings have wrong collation of type latin1_swedish_ci on field users_ip jgjmr_kunena_pratings have wrong collation of type latin1_swedish_ci on field option
htaccess: Exists | PHP environment: Max execution time: 50000 seconds | Max execution memory: 120M | Max file upload: 40M
Joomla default template details : sj_vinda | author: YouTech Company | version: 1.2.0 | creationdate: Unknown
Kunena default template details : Crypsis | author: Kunena Team | version: 4.0.0 | creationdate: 2015-05-31
Kunena version detailed: Kunena 4.0.0 | 2015-05-31 [ Sunset ]
Third-party components: UddeIM 3.5
Plugins: Search - Kunena Search 3.0.1
Modules: Kunena Latest 3.0.1 | Kunena Login 3.0.1
Last edit: 8 years 10 months ago by randwic.
8 years 10 months ago #4 by randwic
Up please
8 years 10 months ago #5 by xillibit
Replied by xillibit on topic Can not edit profile
Can-you just try with default Joomla! template to see if the issue come from your actual Joomla! template ?
8 years 10 months ago #6 by randwic
That's ok with beez template but not ok with protostar
8 years 10 months ago #7 by randwic
the update still does not allow me to be able to edit the profile
8 years 10 months ago #8 by 810
I thinks its a plugin, conflict.
Disable all none joomla/kunena plugins,check if works then enable them one by one.
8 years 10 months ago #9 by randwic
I disable Kunena plugin one by one but still nothing
8 years 10 months ago - 8 years 10 months ago #10 by sozzled
Replied by sozzled on topic Can not edit profile
I think 810 meant to write "disable all non-Kunena plugins, one by one". In other words, he was probably trying to say that he thinks your problem is not caused by Kunena but by some other extension you are using.
I saw that you were having problems with Tapatalk. Perhaps Tapatalk is the cause of this problem, too?
I also see that your database has the wrong collation for one of your tables (_kunena_pratings). I do not know anything about this table.
Last edit: 8 years 10 months ago by sozzled.
Time to create page: 0.529 seconds
