Question Login Bar Colors
2 years 2 months ago - 2 years 2 months ago #231863 by Maduk
Login Bar Colors was created by Maduk
I am trying to change the colors of the login bar, but im having trouble finding the CSS location for it even using the inspect function in chrome. https://imgur.com/a/bffavQz
imgur.com/a/bffavQz
Last edit: 2 years 2 months ago by Maduk.
2 years 2 months ago #231864 by Pinkeltje
Replied by Pinkeltje on topic Login Bar Colors
Hard to say when seeing only an image. A link to your site would be more helpful.
Suppose you want to change the menu-item colors?
Try this:
#kunena .nav-link.active {   color: red; } #kunena .nav-link {   color: blue; }
2 years 2 months ago #231865 by Maduk
2 years 2 months ago #231866 by Pinkeltje
You don't have a menu, so can't help you with that. But this definition changes the background of the navbar:
#kunena .navbar.navbar-expand-lg.navbar-light.bg-light.shadow-lg.rounded.border {   background-color: #A69D86 !important; }
2 years 2 months ago #231870 by Maduk
Replied by Maduk on topic Login Bar Colors
So i have been editing in the hard CSS, i assume this is an override to use in user.css??
2 years 2 months ago #231871 by Pinkeltje
Yes. You have to add this to your user.css.
Time to create page: 0.214 seconds
