Question no file was uploaded
2 years 8 months ago #1 by martinsai
Hi Team,
in forum I wanted to upload a pdf file with less than 10MB. Max allowed file size is 14MB. I renamed the file, I tried as super admin and as registered user. both ways did not work. I changed htacces which was mentioned in the forum but which sounds strange to me.
Here is my report. The forum is only for registered users.
www.psychoanalyse-muenchen.de/forum?view=topic&catid=13&id=844
shall I send you access as registered user or super admin somehow?
Database collation check:
htaccess: Exists | PHP environment: Max execution time: 50000 seconds | Max execution memory: -1 | Max file upload: 64M
Joomla default template details : jp-scene | author: JoomlaPlates | version: 1.0.004 | creationdate: June 2014
Kunena default template details : Blue Eagle5 | author: Kunena Team | version: 1.6.3 | creationdate: 2021-03-10
Kunena template params:
Kunena version detailed: Kunena 5.2.4 | 2021-04-04 [ Koios ]
Plugins: None
2 years 8 months ago #2 by rich
Replied by rich on topic no file was uploaded
Does it work with other attachments like zip files? I see in their configuration report the strange value Max execution memory: -1 in the server configuration.
2 years 8 months ago #3 by martinsai
Replied by martinsai on topic no file was uploaded
Hey Rich
thnx, png, jpg and zip worked...but why not pdf??? it is also allowed
and yes u r wright about memory limit. In the php.ini file actually the limit was more than 500MB....I dont know why they wright -1.....will call hoster tomorrow
2 years 8 months ago #4 by martinsai
Hi Rich,
really strange, i tried some other pdfs and it worked, just the one I wanted to upload did not work.....I changed file name still no success
2 years 8 months ago - 2 years 8 months ago #5 by martinsai
Hi Rich,
I compressed it down to 700kb. and it worked. But in Kunena frontend it says that we can upload up to 14MB. So why did it not accept 10MB?
Last edit: 2 years 8 months ago by martinsai.
2 years 8 months ago #6 by rich
Did you get a message like "Attachment file size exceed limit allowed by configuration"? If not, then the upload was not yet finished. I tested it with a file of similar size. 10 MB is very big. The upload time was 64 seconds.
2 years 8 months ago - 2 years 8 months ago #7 by martinsai
...no i didnt receive this kind of message. the message was short: "no file was uploaded!" this message came after around 8 seconds. you mean that something went wrong with max. execution time? in system infos the max execution is 50000; upload max filesize 64M
2 years 8 months ago #8 by rich
Yes, that's correct but the execution memory is -1. I'm not sure if your problem is caused by this wrong value, but it' possible.
The following user(s) said Thank You: martinsai
2 years 8 months ago #9 by martinsai
Thank you, I will contact the hoster about execution memory
2 years 8 months ago #10 by martinsai
Hi Rich,
I have increased the memory limit now to
memory_limit = 256M
session.auto_start = on
upload_max_filesize = 128M
max_input_vars = 128M
max_execution_time = 300
still it does not work....I am waiting for another answer from the hoster
Time to create page: 0.434 seconds
