Please Read This First:
Do not use this category for:
Solved Login Issue - Template
5 years 5 months ago - 5 years 5 months ago #217723 by viper_iii
<Solved>
Know the issue is a darn template / plugin but not sure what is causing it..
have most disabled...
or where or what to place the edit.. less.css or in theme??? and what exactly would get it working on primary site...
main site:
www.sclr.org/roverboard
just doesn't do anything with login...
test site
beta.sclr.org/roverboard-0
login works but if you click in chrome it will dissappear if you don't enter user pass
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 20M
Joomla default template details : shaper_helixultimate | author: JoomShaper.com | version: 2.0.0-beta.2 | creationdate: Feb 2018
Kunena default template details : Crypsisb4 | author: Kunena Team | version: 5.2.5 | creationdate: 2021-05-30
Kunena template params:
Kunena version detailed: Kunena 5.2.5 | 2021-05-30 [ Ligeia ]
Third-party components: CommunityBuilder 2.6.0+build.2021.05.20.15.15.36.c7bc73d0f | UddeIM 3.7
Plugins: Search - Kunena Search 5.2.1 | Content - Kunena Discuss 5.2.1
Modules: Kunena Latest 5.2.1 | Kunena Stats 5.2.1 | Kunena Login 5.2.1 | Kunena Search 5.2.1
Last edit: 5 years 5 months ago by viper_iii. Reason: added solved
5 years 5 months ago #217724 by 9themestore
Replied by 9themestore on topic Login Issue - Template
The helixultimate beta 2.0.0 template is using the Bootstrap 5 framework, so the Crypsisb4 template is only compatible with Bootstrap 4 framework. That is the reason of login issue.
- Solution (you need update html mockup of login and logout file).
1. Open the desktop.php file in the "components\com_kunena\template\crypsisb4\layouts\widget\login\login" path.
- Replace:
<a href="#" class="dropdown-toggle" data-toggle="dropdown" id="klogin-desktop">
by
<a href="#" class="dropdown-toggle" data-bs-toggle="dropdown" id="klogin-desktop">
- Replace:
<div class="dropdown-menu dropdown-menu-right" id="userdropdown">
by
<div class="dropdown-menu dropdown-menu-right" id="userdropdown" aria-labelledby="klogin-desktop">
2. Open the logout.php file in the "components\com_kunena\template\crypsisb4\layouts\widget\login\logout" path.
- Replace:
<a href="#" class="dropdown-toggle" data-toggle="dropdown">
by
<a href="#" class="dropdown-toggle" data-bs-toggle="dropdown" id="klogout">
- Replace:
<div class="dropdown-menu dropdown-menu-right" id="nav-menu userdropdownlogout" role="menu">
by
<div class="dropdown-menu dropdown-menu-right" id="nav-menu userdropdownlogout" role="menu" aria-labelledby="klogout">
3. Save and reload your forum to view all changes.
Let us know if it does not work.
Best regards,
The following user(s) said Thank You: viper_iii
5 years 5 months ago - 5 years 5 months ago #217734 by viper_iii
Replied by viper_iii on topic Login Issue - Template
working on these now..
that makes sense...
THANK YOU
file path ..
Logout -
only have default.php in
/htdocs/components/com_kunena/template/crypsisb4/layouts/widget/login
But That did indeed fix it!
5 years 5 months ago #217837 by viper_iii
mobile still had issues..
rolled theme back to normal helix ulitimate version that is Bootstrap 4.
seems to have resolved it and un-did edits - dropdowns working again.
Still many thanks for those edits to test with.
Time to create page: 0.218 seconds
