Question User Rank Titles ?
5 years 3 months ago - 5 years 3 months ago #215734 by KZQ
User Rank Titles ? was created by KZQ
Kunena 5.2.2
I've gotten some complaints from members that their ranks have changed to "New Member". A check in the backend and I see that Kunena|Users|Rank Title drop down list is now filled with "Com_Kunena_Sample Data..." where before there were proper rank titles. This is new, probably since I updated to Version 5.2.2.
I've also a question about subscriptions but I'll make another post for that issue.
Thank You
Bill
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 256M | Max file upload: 256M
Joomla default template details : js_wylia2 | author: Joomlashack | version: 2.2.17 | creationdate: November 26 2020
Kunena default template details : Blue Eagle5 | author: Kunena Team | version: 1.5.2 | creationdate: 2018-12-11
Kunena template params:
Kunena version detailed: Kunena 5.2.2 | 2021-01-13 [ Iris ]
Third-party components: UddeIM 4.0
Plugins: None
Last edit: 5 years 3 months ago by KZQ.
5 years 3 months ago #215737 by KZQ
Replied by KZQ on topic User Rank Titles ?
I've figured out the ranks. Didn't even need the language over rides. Kunena | Ranks select the rank, edit it and replace the sample data text with the rank title I previously had and save the change. Had to do it for each rank.
Problem solved. Thank you
Bill
5 years 3 months ago #215740 by Slacker
Replied by Slacker on topic User Rank Titles ?
I got exactly the same and changed like you manually. Previous upgrades never gave this effect.
5 years 3 months ago #215748 by rich
Replied by rich on topic User Rank Titles ?
5 years 1 month ago #216436 by KZQ
Hi Folks,
There is a check box labeled "Special" for each rank title.
What is the significance of this status?
TIA
Bill
5 years 1 month ago #216475 by xillibit
Replied by xillibit on topic User Rank Titles ?
The special box is just to differenciate the normal user from moderator/banned/blocked/guest
Time to create page: 0.279 seconds
