- Thank you received: 2
Solved Error making backup
You should contact the support of extension esayjoomlabackup or you can try akeeba backup
- Kubik-Rubik
- Moderator
- Thank you received: 18
I already fixed this in the latest build. Please re-download the package and overwrite your existing instance: kubik-rubik.de/downloads/ejb-easy-joomla-backup/joomla-3
Have success!
Kubik-Rubik Joomla! Extensions
kubik-rubik.de
I have downloaded the zipfile and installed it, but get same error ?
- Kubik-Rubik
- Moderator
this is not possible, the error cannot be the same.
In the latest package line 117 is a blank line, so the PHP parser cannot throw an error there:
Are you sure you have the correct version? Did you enter a Donation Code in the settings of the component?
Cheers
kubik-rubik.de
Kubik-Rubik wrote: Hey Per,
Cheers
Hi.
No iam not shure at all
And i did not enter a Donation code, cause i dont have one :whistle:
- Kubik-Rubik
- Moderator
Cheers
kubik-rubik.de
