Question can change the topic title when replying ....
7 years 9 months ago #207499 by pulsarinformatique
Hi
I find very strage that anyone can change the topic title when he adds a reply. Why this feature ? How can we deactivate it please?
thanks
cyril
7 years 9 months ago #207543 by rich
That's a known bug. Disable "Let users edit the subject" in the configuration (tab Frontend).
7 years 7 months ago #209130 by Mathyas
rich wrote: That's a known bug...
When is it expected to solve the problem? :)
A long time ago, in a galaxy far far away,
An old wise computer once said...
00010110010001010001010
7 years 7 months ago #209132 by rich
It is already fixed. You've not tested it before you asked?
But now is another bug. It's not possible to change the topic title even if you have allowed it in the configuration.
7 years 7 months ago #209136 by Mathyas
rich wrote: You've not tested it before you asked?
Of course I tried it
When I writing a new post, the full topic title is changed to the name given in the subject field.
7 years 7 months ago - 7 years 7 months ago #209165 by rich
[strike]Which Kunena version use you?[/strike]
Ok, I found it. You has tested as Admin or Global Moderator and I've tested it as normal registered user.You are right, the bug still exists if you are logged in as Admin or global Mod.
Last edit: 7 years 7 months ago by rich.
