- Thank you received: 1
Solved After upgrade from 5.1.3 to 5.1.4 many things are broken!!!
- webmasterinaffitto
- Junior Member
7 years 7 months ago - 7 years 7 months ago #204320
by webmasterinaffitto
I've just update the forum to 5.1.4 and:
1) the avatar of users at the right of any discussion are HUGE!!!
2) I have some sections and forums... now they are shuffle! The name of a section is above the forums of another section... it's not possible to understant nothing anymore... even if I've tried to change the order into back end ( but there are as I've creted them) nothing change in front end...
Pls can you check and help me?
PS The problem seems to be only with template: Crypsis
Last edit: 7 years 7 months ago by webmasterinaffitto.
7 years 7 months ago #204327
by rich
Replied by rich on topic After upgrade from 5.1.3 to 5.1.4 many things are broken!!!
I'm sorry, but can't reproduce this error. When we can't see the error on your page, it's not possible to help.
7 years 7 months ago - 7 years 7 months ago #204333
by Slacker
Replied by Slacker on topic After upgrade from 5.1.3 to 5.1.4 many things are broken!!!
After my upgrade to 5.1.4 I lost bootstrap, so the forum did not show up nice. I had Beez3 template so in its setting I added bootstrap support to com_kunena (Advamced settings). I had also to in Crypsis setting Icon type: change to Fontawesom. Then it works but the forum loaded slow. I had to disable bootstrap in Crypsis Advanced Load bootstrap CSS from Yes to NO.
Last edit: 7 years 7 months ago by Slacker.
7 years 7 months ago - 7 years 7 months ago #204354
by rich
Yes, I confirm this issue. The bootstrap.css will not loaded also when is the setting Load bootstrap css = yes.
Solution:
Open the template.php, path is /components/com_kunena/template/crypsis/template.php
Change the lines 87-89
from
to
That should solves this problem.
Solution:
from
$this->addStyleSheet(Uri::base(true) . '/media/jui/css/bootstrap.min.css');
$this->addStyleSheet(Uri::base(true) . '/media/jui/css/bootstrap-extended.css');
$this->addStyleSheet(Uri::base(true) . '/media/jui/css/bootstrap-responsive.min.css');
$doc = JFactory::getDocument();
$doc->addStyleSheet(Uri::base(true) . '/media/jui/css/bootstrap.min.css');
$doc->addStyleSheet(Uri::base(true) . '/media/jui/css/bootstrap-extended.css');
$doc->addStyleSheet(Uri::base(true) . '/media/jui/css/bootstrap-responsive.min.css');
Last edit: 7 years 7 months ago by rich.
7 years 7 months ago - 7 years 7 months ago #204368
by Slacker
I tried it for PHP 7.1,15 and I got this error and could not access forum in front end:
#0 Call to a member function addStyleSheet() on null
Its when Bootstrap Yes, when Bootstrap No no error.
I looked in error logs of Xampp:
[Wed Sep 26 17:10:48.777637 2018] [php7:notice] [pid 10960:tid 1932] [client ::1:53563] PHP Notice: Undefined variable: doc in C:\\xampp\\htdocs\\John\\components\\com_kunena\\template\\crypsis\\template.php on line 87,
7 years 7 months ago #204374
by rich
@Slacker
Please create a new topic. The error message has nothing to do with the bootstrap.css
Time to create page: 0.217 seconds
