Topics must relate to a currently supported version of Kunena. If you are unsure what is the current supported version of Kunena, please go to the
download
page.
Question Hacked via com_kunena/template/cripsys/assets
8 years 6 months ago #198729
by uzbaby
Hacked via com_kunena/template/cripsys/assets was created by uzbaby
Hello. This morning I got malware problems. I got lots of cache files and my site was desactivated. In my hosting they said that trouble comes from com_kunena/template/cripsys/assets folder.
How can I find there malicious files?
8 years 6 months ago #198737
by 810
Replied by 810 on topic Hacked via com_kunena/template/cripsys/assets
What kind of malware problems do you have? Which hosting provider do you having.
Also please add kunena report.
8 years 6 months ago #198748
by uzbaby
Replied by uzbaby on topic Hacked via com_kunena/template/cripsys/assets
Thnak you.
In the attachment my malware file.
My hosting is bluehost.
Rigth now I can't make kunena report due to my site is down. Can I do it via hosting? Can you please explain how?
8 years 6 months ago #198749
by uzbaby
malware file in the attachment
8 years 6 months ago #198750
by 810
You need access to the backend.
Else download your site, and use a localhost.
blog.sucuri.net/2017/02/joomla-security-...ign-in-the-wild.html
You need to look into your files to: base64_decode, we use this codes.
if you see any code like:
Then you are infected.
$return = base64_decode($input->post->get('return', '', 'BASE64'));
$return = base64_decode($this->app->input->getBase64('return'));
base64_decode("VHJhY3RvciBNb3VudGVkIExhbmRzY2..Z1ZWwgQ2hpcHBlcnM8YSBocmVmPSJodHRwOi8vam
F2cmlwLm5ldCIgc3R5bGU9InBvc2l0aW9uOmFic29sdXRlOyBsZWZ0Oi0xMjc1cHg7IHRvcDowIj5qYXZyaXAubmV0PC9hPg"),
8 years 6 months ago #198757
by uzbaby
I have access to backend. But which file should I check?
All files from com_kunena/template/cripsys/assets folder?
But there lots of files are just image files.
Should I search in some another files?
Time to create page: 0.353 seconds
