Solved [Solved] How to disable status feature from Kunena?
9 years 4 months ago - 9 years 3 months ago #188329 by WinniePooh
Hello everyone,
Kunena 5 introduced a new feature which let user set their own status (online, away, busy, invisible) and status text. It might be useful for others, but I would like to remove this feature. How do I disable it? I couldn't find any options in the settings to disable the status completly.
Regards
Last edit: 9 years 3 months ago by WinniePooh.
9 years 4 months ago - 9 years 4 months ago #188337 by rich
The easiest way if you hide it with a css code. Add this code in your custom.less . But then remain the divider lines.
form#status-form, div#statustext { display: none; }
If you want also remove the divider, you need Template Overrides . You find the tables in "components/com_kunena/template/crypsis/layouts/widget/login/logout/default.php"
Copy this file to "your-joomla-template/html/com_kunena/template/crypsis/layouts/widget/login/logout/" and comment out (or remove) the unwanted tables and divider lines.
But this removes not already existing personal text.
Last edit: 9 years 4 months ago by rich.
The following user(s) said Thank You: WinniePooh
9 years 3 months ago #194619 by WinniePooh
Sorry for the late reply. Thank you rich as always for your help.
One thing I need to correct:
The override path for Kunena 5 should be "your-joomla-template/html/com_kunena/layouts/widget/login/logout/" - the "template/crypsis" needs to be removed.
9 years 3 months ago #194626 by rich
Yes, you're right. Thanks for the hint!
