Solved Sudden problem with a topic
9 years 8 months ago - 9 years 8 months ago #184357 by Nikiniko
this happened only to one topic
the initial url was
and is not working with error 404 Not Found nginx
but this is working
What can be wrong ?
Last edit: 9 years 8 months ago by rich. Reason: Links made invisible
9 years 8 months ago #184358 by Nikiniko
I renamed it test test and is working,
i renamed it back to the original name and is not working
9 years 8 months ago #184360 by rich
Replied by rich on topic Sudden problem with a topic
We had already times a discussion about links to your adult forum? Anyway, it will not tolerated if they are publicly posted. If a link to get help is unavoidable, then use the confidential tags.
9 years 8 months ago #184367 by Nikiniko
you can see that there is a problem and i am not doing it to advertise, firts time i hear for confidential tags.
9 years 8 months ago #184380 by rich
Nikiniko wrote: you can see that there is a problem and i am not doing it to advertise, firts time i hear for confidential tags.
Ok, we forget it. The confidential tag is the Closed symbol in the editor.
Try rename it back again, then go in the backend to Kunena -> Tools and let count all statistics new. Check also in the trash whether is contained a topic with the same or similar name.
The following user(s) said Thank You: Nikiniko
9 years 8 months ago #184426 by Nikiniko
I found it in the trash 1 post of the topic what i do ?
