This category is only for reporting defects or problems with Kunena 2.0 test versions. This is NOT a support forum - there is no support for test versions. Users should NOT install K 2.0 alpha or beta test versions on websites with live production data.
Wherever possible, please include your K 2.0 configuration report.
Solved K 2.0 RC2 Installation Error "JFolder: :folder: Path is not a folder"
14 years 5 months ago - 14 years 5 months ago #125882 by nathan2226
It installs correctly, however below that, this message appears:
JFolder: :folder: Path is not a folder. Path: /components/com_kunena/template/mirage
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 2M
Joomla default template details : joomlage0056-designcanvas | author: Joomlage.com | version: 1.0 | creationdate: May 2012
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.0-RC2 | creationdate: 2012-06-10
Kunena version detailled: Kunena 2.0.0-RC2 | 2012-06-10 [ E-Prime ]
| Kunena detailled configuration:
| Joomla! detailled language files installed:
Plugins: None
Last edit: 14 years 5 months ago by Matias.
14 years 5 months ago #125892 by Matias
You can ignore this error. It's just used to clean up older version of template that doesn't exist. We will fix the issue for the stable release.
14 years 5 months ago #125899 by MarioMari
but I'd like to test this template "Mirage" name already I like it ;)
P.S.
The same error in com_kunena_v2.0.0-RC2_2012-06-10.zip
14 years 5 months ago #125926 by coder4life
Mirage is still in its conceptual stage and is not ready to be tested, many incomplete parts. We will provide testing releases before the release of the template in a later version of Kunena.
14 years 5 months ago - 14 years 5 months ago #125941 by Matias
Error should be fixed for the next version.
14 years 5 months ago #125978 by baazza
K 2.0 RC3 Installation Error
JFolder: :المجلد: المسار لايؤدي إلى مجلد. المسار: C:\xampp\htdocs\kunena\components\com_kunena\template\blue_eagle
JFolder: :المجلد: المسار لايؤدي إلى مجلد. المسار: C:\xampp\htdocs\kunena\components\com_kunena\template\mirage
JFolder: :folder: Path is not a folder. Path: C:\xampp\htdocs\kunena2\components\com_kunena\template\blue_eagle
JFolder: :folder: Path is not a folder. Path: C:\xampp\htdocs\kunena2\components\com_kunena\template\mirage
1062 - لقد حصل خطأ!.
Duplicate entry '' for key 'alias' SQL=INSERT INTO `oyja2_kunena_aliases` (`alias`, `type`, `item`, `state`) VALUES ('suggestion-box', 'catid', '1', 1), ('', 'catid', '2', 1), ('', 'catid', '3', 1);
500 - لقد حصل خطأ!.
يوجد عنصر قائمة آخر في نفس القائمة الأم له نفس الاسم المستعار
There is another list item in the same has the same alias
htaccess: Missing | PHP environment: Max execution time: 330 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : beez_20 | author: Angie Radtke | version: 2.5.0 | creationdate: 25 November 2009
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.0-RC3-DEV | creationdate: 2012-06-10
Kunena version detailled: Kunena 2.0.0-RC3-DEV | 2012-06-10 [ Internal ]
Plugins: None
baazza
رضيت بالله ربا وبالاسلام دينا وبمحمد صلى الله عليه وسلم رسولا
testify & witness that there is no god worthy of being worshipped other than Allah and that Mohammad is His Messenger
Time to create page: 0.170 seconds
