Solved Help fixing typo in 2.0.4 Blue Eagle
13 years 3 months ago #139832 by robmd21
Hello, looking for help to find the file where I can edit this typo in my default blue eagle template.
the green arrow points to the text "agoby" that should read "ago by".
i apologize if this topic has been addressed. i did do my best to search for a topic first albeit not the most thorough search.
thank you in advance for your help.
13 years 3 months ago #139854 by coder4life
Hello robmd21,
Does this issue occur on Kunena.org?
I do not know exactly what page/section of Kunena you are looking at, however I would suspect this to be a CSS issue not a typo. The spacing between those two items is a result of padding made by CSS.
Please check with your template provider, and make sure your template provider is not overriding some CSS.
13 years 3 months ago #139856 by robmd21
coder4life wrote: Hello robmd21,
the page i'm looking at is the RECENT TOPICS page. i'm using the blue eagle template from kunena on the milkyway joomla template.
it does not occur here. you are correct.
13 years 3 months ago #139858 by sozzled
I am sure this problem was cured about two releases ago. Can you please post your configuration report here?
13 years 3 months ago - 13 years 3 months ago #139859 by robmd21
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 32M
Joomla default template details : rhuk_milkyway | author: Andy Miller | version: 1.0.2 | creationdate: 11/20/06
Third-party components: UddeIM 2.5
Plugins: Search - Kunena Search 2.0.4 | Content - Kunena Discuss 2.0.4
Modules: Kunena Stats 1.6.4 | Kunena Login 1.7.0 | Kunena Search 1.6.4
Last edit: 13 years 3 months ago by robmd21.
13 years 3 months ago #139863 by sozzled
I thought so. You are using an out-of-date template that is no longer supported by the team. Use the K 2.0 Blue Eagle template instead.
You also need to update the following modules: Kunena Stats 1.6.4, Kunena Login 1.7.0, Kunena Search 1.6.4. These, too, are out-of-date and incompatible with K 2.0.4 (as explained in the K 2.0.4 release notes and in the Wiki article Kunena Add-ons ).
Time to create page: 0.235 seconds
