Kunena 7.0.8 Released
Question Read more link to full article tabs rules and help
14 years 2 weeks ago - 14 years 2 weeks ago #129787 by gimenezadrian
I put in the rules menu
[article=full]1[/article]
and i get read more link
Choose how to display configuration article by default does nothing, since nothing has to do
No read more in article
I post here in case anyone finds the solution
K 2.0.1
¿Article full not working?
Last edit: 14 years 2 weeks ago by gimenezadrian.
14 years 2 weeks ago #130148 by achartier
I am having the same problem. Also, all text included in the Rules or Help article is displaying in italics and all spaces are being stripped. I imaging this is a css problem but not sure where to fix it.
14 years 1 week ago #130696 by achartier
The stripped spaces turned out to be an artifact of attempting to use a slider inside the article.
I would still like to see some way to override the italics style.
13 years 8 months ago - 13 years 8 months ago #137094 by Jazzvox
Same problem! In addition, we get some more "Just Another Homemade SEO-Killer"s like:
/component/content/article/2-uncategorised/48-help.html
I found this thread in the German forum: www.kunena.org/forum/36-German/123781-re...-lesen-button-stoert
After reading this, until the bug is fixed, I thought this could work:
In bbcode.php remove line 1193:
case 'full': if ( !empty($article->fulltext) ) { $article->text = $article->introtext. ' '. $article->fulltext; // $link = '<a href="'.$url.'" class="readon">'.JText::sprintf('COM_KUNENA_LIB_BBCODE_ARTICLE_READ').'</a>'; break; }
Despite it seems to be logical, this doesn't work, the unwanted "readon" still appears.
Might be anything wrong with this condition
'$article->text = $article->introtext. ' '. $article->fulltext;'
or the latter
case 'intro': ... $article->text = $article->introtext;
Sorry, but I'm not a versed coder, any idea ??
Last edit: 13 years 8 months ago by sozzled. Reason: Removed user's signature under Section 7.3 of terms of use
13 years 8 months ago #137113 by rich
13 years 6 months ago #139342 by Hoffi
as posted in the german forum (see link in rich's post) I have found the cause for the wrong link text as well as a nice "hack" we use on our site to let the admin/user skip the link if not needed.
In case of articles without a "read more" tag all the text is stored in introtext member of article object. So the code in the "case full" block (in bbcode.php, you know ;)) is not executed. Instead it falls through to the "case intro" block and shows the "Read more" link.
I think the code needs to become a bit more complex to follow these rules:
If "full" is requested and introtext OR fulltext contain some text, all text and "Read article" link should be shown.
If "intro" is requested and introtext is present, this text should be shown. If fulltext isn't empty too "Read more" link should be shown, otherwise "Read article" link.
Additionally my "hack": I used additional value "fullnolink" instead of "full" in which case I don't add the "Read article" link (see code below).
Here my code (without fulltext check in intro part because we don't need this), corresponding to bbcode.php lines 1189++ in Kunena 2.0.3:
switch ($default) { // Hoffi: (a) fix introtext-only, (b) allow full w/o link (use [article=fullnolink] instead of [article=full]) case 'fullnolink': case 'full': if ( !empty($article->fulltext) || !empty($article->introtext) ) { if ( !empty($article->fulltext) && !empty($article->introtext) ) { $article->text = $article->introtext . ' ' . $article->fulltext; } else { $article->text = $article->introtext . $article->fulltext; } if ( $default == 'fullnolink' ) { $link = ''; } else { $link = '<a href="'.$url.'" class="readon">'.JText::sprintf('COM_KUNENA_LIB_BBCODE_ARTICLE_READ').'</a>'; } break; } // continue to intro if fulltext is empty case 'intro': //...
I hope this will find it's way into next release ;)
Thanks,
Hoffi
Time to create page: 0.235 seconds
