Question [RESOLVED}Users can delete their own posts
14 years 3 months ago - 14 years 3 months ago #130438 by jpc0480
I have just discovered another issue that I don't believe is related. Registered users can delete their own posts. I have set in "Security" User Can Delete Own Post: Never
The reg user can only delete his own posts, however they are also able to do this if there has been posts by other members, even admin?
Kunena 3.0.4
CB 1.9.1
Joomla 2.5.18
Last edit: 14 years 3 months ago by jpc0480.
14 years 3 months ago #130444 by Jiminimonka
I just created a post on your website (after registering), and there is no Delete option for me. I can however edit my own post.
songcrypt.net/forum/introductions/11-test-post#18
Perhaps you want to stop people from being able to edit their own posts? That is also configurable in the Kunena admin section.
Please read the FAQ.
Only one question per topic.
14 years 3 months ago #130445 by jpc0480
No I don't get it within the post, it's from the category view. See screenshot.
I can't delete your post as it tells me I do not have moderator privelages, but for mine I can delete it even if there was a post on it.
Kunena 3.0.4
CB 1.9.1
Joomla 2.5.18
14 years 3 months ago #130446 by Jiminimonka
I see, perhaps you have got new users being set to super admins? I think there was an issue with this, something to do with Joomla ACL.
Start by looking here, I have to get lunch sorted for the kids now, so AFK for a while.
www.kunena.org/forum/154-Miscellaneous-o...-As-A-Registered-Uer
14 years 3 months ago #130450 by jpc0480
Thanks, I appreciate the help!
Super admin and admin permission levels are correct. I never modified the .htaccess file other than to change it from htaccess.txt and have just loaded the site. I checked permission settings in the user manager and everyone has the correct label for their position. The only problem is that users can delete their "own" posts, nothing else.
Kunena 3.0.4
CB 1.9.1
Joomla 2.5.18
14 years 3 months ago #130456 by Jiminimonka
I have spoken with Matias, it might be a logic issue, that is already fixed in Kunena 2.0.2 (which is not ready for release yet). Having said that, we will still see if there is something else that might have caused this problem.
The following user(s) said Thank You: jpc0480
