Question KD 2.0.3 plugin does not work
14 years 4 days ago #136982 by jpc0480
I have just upgraded to Kunena 2.0.3 and just tried to integrate the discuss plugin. The plugin does not show a discuss area in the article. Instead when you click the article link you are directly taken to the forum where the new topic has been created. It completely bypasses the article entirely.
I have set the "Default Forum Category" to the corresponding Kunena category ID and I set the "Allowed Content Categories" to the corresponding Joomla Content Category. See screenshot.
I can't figure out how to show the article with the discussion following, with a link to the actual forum post.
Kunena 3.0.4
CB 1.9.1
Joomla 2.5.18
14 years 4 days ago #136984 by 810
Replied by 810 on topic KD 2.0.3 plugin does not work
try the follow settings:
The following user(s) said Thank You: Shynx
14 years 4 days ago - 14 years 4 days ago #136987 by jpc0480
I still couldn't get this to work?
I have set the ID for "Category Mapping" to the Joomla category ID and "Default Forum Category" to the Kunena forum category ID. I am smh here trying to figure this out...? I received the following when I activated debugging:
[KunenaDiscuss debug: Constructor called in com_content ]
[KunenaDiscuss debug: onPrepareContent.Deny: Category 15 was disabled in the category map. ]
[KunenaDiscuss debug: onPrepareContent: we are in article/ page. ]
[KunenaDiscuss debug: onPrepareContent: Article 19 ]
[KunenaDiscuss debug: onPrepareContent: Searched for {kunena_discuss:#}: Custom Topic not found. ]
****EDIT****
I added the content ID to "Allowed" and everything works.
Thanks!
Kunena 3.0.4
CB 1.9.1
Joomla 2.5.18
Last edit: 14 years 4 days ago by jpc0480.
14 years 4 days ago - 14 years 4 days ago #136993 by nemmar
jpc0480 wrote: I still couldn't get this to work?
****EDIT****
I added the content ID to "Allowed" and everything works.Thanks!
I installed the new K2.0.3 updates, including the new Discuss Plugin, and the Discuss plugin is still not working for me.
There is a long post of this issue in the forum but that thread was closed since it was reported that the K2.0.3 Discuss Plugin was fixed:
www.kunena.org/forum/K-2-0-Kunena-Discus...icle?start=10#135567
Can you tell me what you did for the workaround? I'm not clear on what you mean by setting the content ID to "Allowed" and everything then worked with the plugin.
Note to forum moderator: If I posted in the wrong section/thread then let me know and I will move my post to the section of the forum you recommend.
Thanks for any advice!
Last edit: 14 years 4 days ago by nemmar.
14 years 4 days ago #137015 by 810
hi, you must enter a number on "Allowed content id" 0 = every content
14 years 4 days ago #137027 by nemmar
810 wrote: hi, you must enter a number on "Allowed content id" 0 = every content
Hi 810,
I checked my K Discuss plugin settings and I do have the Allowed Content ID at 0.
So should I post the bug/problem with K Discuss 2.0.3 not being fixed yet? The other forum thread was closed since the forum mod wrote the bug was fixed for 2.0.3 before the release of the update.
I'm not sure where to post so the Discuss plugin devs are aware of the issue.
