- Thank you received: 5
Question Kunena Discuss 2.0.1: Guests cannot be the first ones to make a comment on an article
If there a Discussion under a Article everything is fine:
- Captcha runs and the comment is publish
But if there no discussion under the article the discuss plugin didn´t work:
- after fill out the captcha the guest get a blank site. After refresh the screen there is the message that, the captcha code is wrong. But it was right. test it round 50 times
- if I deactivate the captcha-security the guest get the same result. He can fill out the form, but after send there came a blank screen an nothing is published
SSL provide the strongest protection, greatest flexibilty
proterra wrote: my config: guest can write comments over the reCaptcha function
Any fixes there?
The problem happens if you allow guests to write on your forum. If you use CAPTCHA then guests cannot write on your forum, and it doesn't matter whether they get the CAPTCHA code correct or not. No-one can use the Kunena Discuss feature if you allow guests to write on your forum with CAPTCHA enabled. Is that correct?
If you allow guests to write on your forum but you do not use CAPTCHA, then anyone can write on your forum. Is that correct?
It looks like you have not entered set up the CAPTCHA on your system.
sozzled wrote: Let me see if I understand the question.
No that isn´t the problem.
I have entered set up Captcha on the system.
The problem is following:
1. If a discussion is starting by registered users and some comments under a article or in the board everything runs: Guests can post comments with use the captcha. The Comments are display and the captcha runs
2. If there a article with no comments and the guest will start the discussion nothing happens. He fill out the forms and the captcha but get a blank site an after refresh the failure message
