Question K 2.0.2 + J! 5.2.8 + PHP 5.4.7
  • C0n
  • C0n's Avatar Topic Author
  • Offline
  • Premium Member
  • Premium Member
  • Only the strongest will survive
14 years 1 week ago - 14 years 10 hours ago #136810 by C0n
Instaled latest kunena on a fresh joomla 1.5.26 site and it does not work mootools upgrade is enabled there is nothing else instaled other than kunena everything is default to joomla1.5.26
Here is the configuration report -.-
Legacy mode: Disabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Disabled | FTP layer: Enabled |
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 201M
Joomla default template details : rhuk_milkyway | author: Andy Miller | version: 1.0.2 | creationdate: 11/20/06
Plugins: None
Also update your wiki you do not include download links to mootools anywhere we are relying on the mootools upgrade plugin that joomla provides us with....
Last edit: 14 years 10 hours ago by sozzled. Reason: Reveal Kunena configuration report in message
The topic has been locked.
  • C0n
  • Offline
  • Premium Member
  • Premium Member
14 years 1 week ago - 14 years 1 week ago #136811 by C0n
Replied by C0n on topic K 2.0.2 + J! 5.2.8 + PHP 5.4.7
I also have noticed when looking in the modules kunena menu has not created a module ? and there is no way i can create a kunena menu module either....
Last edit: 14 years 1 week ago by C0n.
14 years 1 week ago #136815 by rich
Replied by rich on topic K 2.0.2 + J! 5.2.8 + PHP 5.4.7
I think, your problem is Joomla 1.5 with PHP version: 5.4.7. Joomla 1.5 is probably no longer supported.
  • C0n
  • Offline
  • Premium Member
  • Premium Member
14 years 1 week ago - 14 years 1 week ago #136816 by C0n
If it is no longer supported then you should remove it from the download link on the homepage saying it is supported....rather annoying because this is not the first time i have had a issue with a kunena instilation there have been problems since the 1.6 series but i will migrate to joomla 2.0+ and let you know if the issue still persists.
14 years 1 week ago - 14 years 1 week ago #136819 by rich
Sorry, I think you have misunderstood me. Joomla 1.5 and Kunena 2.0.x is no problem. Problem is Joomla 1.5 with php 5.4.7.
Joomla 1.5 is no longer supported. Is better, if they migrate to Joomla 2.5
Last edit: 14 years 1 week ago by rich.
  • C0n
  • Offline
  • Premium Member
  • Premium Member
14 years 1 week ago - 14 years 1 day ago #136820 by C0n
Well fresh instal with 2.0.2 and the latest joomla version and still the same issue -.-
Fatal Error: Call to a member function getMenu() on a non-object in components/com_kunena/libraries/route/route.php on line 273
The error was detected in the Kunena Component.
something wrong with the kunena menu.
Legacy mode: Disabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Disabled | FTP layer: Enabled |
Joomla default template details : beez_20 | author: Angie Radtke | version: 2.5.0 | creationdate: 25 November 2009
Plugins: None
If you want admin or ftp access i will be happy to provide you with one but from what i see it is a kunena issue.
Last edit: 14 years 1 day ago by sozzled. Reason: Reveal configuration report
Time to create page: 0.151 seconds
