Question Where did default profile contents moved to?
13 years 8 months ago #141235 by sunny33days
Hi, in previous Kunena 1.6 and 1.7 versions, the profiles/avatars next to their posts were controlled by this file path: components/com_kunena/template/default/view/profile.vertical.php
I upgraded to Kunena 2.0.4, and although this file is still there, it seems it's not being used for this purpose now. Can you tell me the new file and file path that is overriding this with Kunean 2.0.4?
13 years 8 months ago #141236 by TKtemp
components / com_kunena / template / blue_eagle / html / topic / default_profile_vertical.php
The following user(s) said Thank You: sunny33days
13 years 8 months ago - 13 years 8 months ago #141245 by sunny33days
Wow good catch. I can see the changes now.. :). Are you also part of the Kunena project.
When I upgraded to Kunena 2.0.4 last night, my Jawards integration stopped working in Kunean (it's suppose to show awards below their avatars in their forum posts). This code worked in all prevous Kunena versions, however stopped working in Kunean 2.0.4 for some reason. The awards are linking up correctly to the jawards they've won, it's just the images aren't displaying. Any idea what should be changed to update it to work with Kunena 2.0.4? This is the code that worked with Kunena 1.6 and 1.7. It workded with Joomla 1.5, 1.6, 1.7, and 2.5, it only stopped working when I upgraded to Kunean 2.0:
www.kunena.org/forum/k-1-6-and-k-1-7-mis...-jawards-integration
Last edit: 13 years 8 months ago by sunny33days.
13 years 8 months ago #141246 by sunny33days
I'm still having a hard time figuring out how to get the code to past in here, but this is the code I'm referencing here: www.kunena.org/forum/k-1-6-and-k-1-7-mis...-jawards-integration
13 years 8 months ago #141270 by TKtemp
try with this
<?php // Hack for jAwards integration, displays some medals of the user for Kunena 1.6 $number_medals = 10; // number of medals to show $query = "SELECT b.image, b.name" . "\n FROM #__jawards_awards AS a" . "\n LEFT JOIN #__jawards_medals AS b ON b.id = a.award" . "\n WHERE a.userid=". $this->profile->userid . "\n ORDER BY RAND() LIMIT ".$number_medals; $database = &JFactory::getDbo(); $database->setQuery( $query ); $medals = $database->loadObjectList(); // URL links to the jAwards-Tab for Community Builder which displays all // medals of the user - change to another URL of needed $awards_url=JRoute::_('index.php?option=com_comprofiler&task=userProfile&user='.$this->profile->userid."&tab=getawardstab"); // CSS-class "ja_medals" allows individual styling of medal images and // container. "nobr" keeps the medals from breaking apart, display them // in one row. $msg_jawards = "<div class=\"ja_medals\"><nobr>"; foreach ($medals as $med){ $msg_jawards.= "<a href=\"$awards_url\" title=\"$med->name\">" . "<img style='border:0px;padding:0px;' src=\"".JURI::root(true)."/images/medals/".$med->image ."\" alt=\"".$med->name."\" />" . "</a>"; } $msg_jawards.="</nobr></div>"; unset($medals); echo $msg_jawards; ?>
13 years 8 months ago #141273 by sunny33days
Oh my god, you're a genius!!! THank you so much!
