- Thank you received: 3
Loved converter - project Agora 3.0 to Kunena 2.0 - version 0.2
13 years 5 months ago - 13 years 5 months ago #138777
by rgrae81
converter - project Agora 3.0 to Kunena 2.0 - version 0.2 was created by rgrae81
I had to convert some Topics and Messages from Agora to Kunena, but there's nearly nothing
I decided to write a little PHP file for converting everything I need for myself.
Now I would like to share my work with the community. Maybe some users would complete it to a fully functional Converter.
First of all, synchronize the Joomla-Users.
Then you have to create the categories and subcategories lige in your Agora-Forum.
Follow the instructions in the code to link forums to categories
Upload the saved php-file to your webspace and open it in your browser.
After everything is done, recount statistics under Kunena-Tools
Happy converting
regards
Roman
!!! Updated Version - 0.2 !!!
Changes:
- add functionality to import agora-categories and forums with standard permissions
- automattically maps new category-id with old agora forum id
Convertion-Steps:
After everything is done, press "recount statistics" under Kunena-Tools
Happy converting
regards
Roman
Changes:
Convertion-Steps:
<?php
// AGORA 3.0.x to Kunena 2.0.x converter //////////////////////////////////////////////////////////////////////////////////////
// Converter version 0.2 //////////////////////////////////////////////////////////////////////////////////////
//enter your database credentials here.
$host = "localhost";
$user = "";
$pass = "";
$db = "";
$link = mysql_connect($host,$user,$pass) or die(mysql_error());
mysql_selectdb($db,$link) or die(mysql_error());
$ag_forums_to_kunena_categories = array();
// converting Agora categories to Kunena categories using original category-ID ////////////////////////////////////////////////
mysql_query("TRUNCATE j25_kunena_categories");
$sql = "
SELECT
c.id AS categories_id,
c.cat_name AS categories_name,
c.disp_position AS categories_ordering,
c.enable AS categories_published
FROM jos_agora_categories AS c
ORDER BY c.disp_position ASC
$res = mysql_query($sql) or die(mysql_error());
while ($row = mysql_fetch_object($res))
echo $row->c.id;
echo "<br />";
$sql = "INSERT INTO `j25_kunena_categories` VALUES (".$row->categories_id.", 0, '".mysql_real_escape_string($row->categories_name)."', '', 0, 0, 'joomla.group', 2, 2, 1, 8, 0, ".$row->categories_ordering.", ".$row->categories_published.", NULL, 0, '0000-00-00 00:00:00', 0, 0, 0, 0, '', '', '', 0, 'lastpost', 0, 0, 0, 0, 0, '{}')";
echo $sql;
echo "<br />";
// converting Agora Forums to Kunena categories using modified category-ID ////////////////////////////////////////////////////
// first of all count how many agory categories are here. Start catid plus 1 for Forums ///////////////////////////////////////
$sqlnum = "SELECT * FROM jos_agora_categories";
$resnum = mysql_query($sqlnum);
$rows = mysql_num_rows($resnum);
$cat_mod_id=$rows+1;
$sql = "
SELECT
f.id AS categories_id,
f.enable AS categories_published,
f.forum_name AS categories_name,
f.forum_desc AS categories_description,
f.num_topics AS categories_numTopics,
f.num_posts AS categories_numPosts,
f.last_post AS categories_last_post_time,
f.last_post_id AS categories_last_post_id,
f.disp_position AS categories_ordering,
f.cat_id AS categories_parent_id,
f.closed AS categories_locked
FROM jos_agora_forums AS f
ORDER BY f.disp_position ASC
echo $cat_mod_id;
echo "<br />";
if($row->categories_last_post_time == '')
$row->categories_last_post_time = 0;
$row->categories_last_post_id = 0;
echo $row->categories_last_post_time;
echo "<br />";
$sql = "INSERT INTO `j25_kunena_categories` VALUES (".$cat_mod_id.", ".$row->categories_parent_id.", '".mysql_real_escape_string($row->categories_name)."', '', 0, 0, 'joomla.group', 1, 2, 1, 8, 0, ".$row->categories_ordering.", 1, NULL, 0, '0000-00-00 00:00:00', 0, 0, 0, 0, '".mysql_real_escape_string($row->categories_description)."', '', '', 1, 'lastpost', ".$row->categories_numTopics.", ".$row->categories_numPosts.", 0, ".$row->categories_last_post_id.", ".$row->categories_last_post_time.", '{\"access_post\":[\"6\",\"7\",\"2\",\"3\",\"4\",\"5\",\"8\"],\"access_reply\":[\"6\",\"7\",\"2\",\"3\",\"4\",\"5\",\"8\"]}')";
echo $sql;
echo "<br />";
$ag_forums_to_kunena_categories [$row->categories_id] = $cat_mod_id;
$cat_mod_id++;
echo "ARRAY:";
echo "<br />";
print_r($ag_forums_to_kunena_categories);
// convert topics from Agora to Kunena ////////////////////////////////////////////////////////////////////////////////////////
mysql_query("TRUNCATE j25_kunena_topics");
$sql = "
SELECT
t.id AS topic_id,
t.poster AS topic_poster,
t.subject AS topic_subject,
t.posted AS topic_first_post_time,
t.last_post AS topic_last_post_time,
t.last_post_id AS topic_last_post_id,
t.last_poster AS topic_last_poster,
t.num_views AS topic_hits,
t.num_replies AS topic_posts,
t.closed AS topic_locked,
t.sticky AS topic_hold,
t.moved_to AS topic_moved_id,
t.forum_id AS topic_category_id,
t.question AS topic_poll_id,
p.id AS topic_first_post_id,
p.posted AS topic_first_post_time,
a.jos_id AS topic_first_post_userid,
p.message AS topic_first_post_message
FROM jos_agora_topics AS t
LEFT JOIN jos_agora_users AS a ON a.username = t.poster
LEFT JOIN jos_agora_posts AS p ON t.posted = p.posted
ORDER BY t.id ASC
echo $row->topic_id;
echo "<br />";
if($row->topic_first_post_userid == '')
$row->topic_first_post_userid = 0;
$cat_id = $ag_forums_to_kunena_categories[$row->topic_category_id];
echo $cat_id;
echo "<br />";
$sql = "INSERT INTO `j25_kunena_topics` VALUES (".$row->topic_id.", ".$cat_id.", '".mysql_escape_string($row->topic_subject)."', 0, ".$row->topic_locked.", ".$row->topic_hold.", 0, ".$row->topic_posts.", ".$row->topic_hits.", 0, 0, 0, ".$row->topic_first_post_id.", ".$row->topic_first_post_time.", ".$row->topic_first_post_userid.", '".mysql_escape_string($row->topic_first_post_message)."', NULL, ".$row->topic_last_post_id.", ".$row->topic_last_post_time.", 0, NULL, NULL, '')";
echo $sql;
echo "<br />";
$sql = "
SELECT
t.id AS topic_id,
a.jos_id AS topic_last_post_userid,
p.message AS topic_last_post_message
LEFT JOIN jos_agora_users AS a ON a.username = t.last_poster
LEFT JOIN jos_agora_posts AS p ON t.last_post_id = p.id
ORDER BY t.id ASC
echo "<br />";
$topic_last_post_message = mysql_real_escape_string($row->topic_last_post_message);
if($row->topic_last_post_userid == '')
$row->topic_last_post_userid = 0;
echo $cat_id;
echo "<br />";
$sql = "UPDATE `j25_kunena_topics` SET `last_post_id` = ".$row->topic_last_post_id.",`last_post_time` = ".$row->topic_last_post_time.",`last_post_userid` = ".$row->topic_last_post_userid.",`last_post_message` = '".mysql_escape_string($row->topic_last_post_message)."',`last_post_guest_name` = NULL,`params` = '' WHERE `j25_kunena_topics`.`id` = ".$row->topic_id."";
echo $sql;
echo "<br />";
// convert Posts from Agora tu Kunena /////////////////////////////////////////////////////////////////////////////////////////
mysql_query("TRUNCATE j25_kunena_messages");
mysql_query("TRUNCATE j25_kunena_messages_text");
$sql = "
SELECT
p.id AS messages_id,
u.name AS messages_name,
a.jos_id AS messages_userid,
p.message AS messages_text_message,
p.posted AS messages_time,
p.edited AS messages_modified_time,
p.edited_by AS messages_modified_by,
p.topic_id AS messages_thread,
t.forum_id AS messages_catid
FROM jos_agora_posts AS p
LEFT JOIN jos_agora_users AS a ON a.username = p.poster
LEFT JOIN jos_agora_topics AS t ON t.id = p.topic_id
LEFT JOIN jos_users AS u ON u.id = a.jos_id
ORDER BY p.id ASC
echo $row->messages_id;
echo "<br />";
if($row->messages_userid == '')
$row->messages_userid = 0;
$cat_id = $ag_forums_to_kunena_categories[$row->messages_catid];
if ($cat_id != 0)
echo $cat_id;
echo "<br />";
$sql = "INSERT INTO `j25_kunena_messages` VALUES (".$row->messages_id.", 0, ".$row->messages_thread.", ".$cat_id.", '".$row->messages_name."', ".$row->messages_userid.", '', '', ".$row->messages_time.", NULL, 0, 0, 0, 0, 0, 0, 0, 0, '')";
$sql2 = "INSERT INTO `j25_kunena_messages_text` VALUES (".$row->messages_id.", '".mysql_escape_string($row->messages_text_message)."')";
echo $sql;
echo "<br />";
echo $sql2;
echo "<br />";
mysql_query($sql2) or die(mysql_error());
mysql_close();
Last edit: 13 years 5 months ago by rgrae81.
The following user(s) said Thank You: Jiminimonka, silentz0r
13 years 5 months ago #138814
by rgrae81
Replied by rgrae81 on topic converter - project Agora 3.0 to Kunena 2.0
New Version 0.2 of the convertion Script.
for further informations read the first Post!
regards
Roman
regards
Roman
13 years 3 months ago - 13 years 3 months ago #140849
by silentz0r
Replied by silentz0r on topic converter - project Agora 3.0 to Kunena 2.0 - version 0.2
Hey, thanks for a great script. However there is a problem with it:
Agora uses Categories, and each category can have many Forums (jos_agora_category and jos_agora_forum MySQL tables). However, Kunena only uses categories (j25_kunena_category MySQL table) and on line 36 you are inserting all jos_agora_category to j25_kunena_category, but on line 81 you also insert jos_agora_forum into j25_kunena_category, which for me at least results in an error "Duplicate entry '6' for key 'PRIMARY'" , because forums and categories have separate ID's on Agora.
I am not sure if this is the way it is supposed to work (insert categories and forums into categories). In Agora every Category has an ID, and every forum has a foreign_key called cat_id which points to the Category it belongs. How do categories and subcategories work in kunena?
In my Agora forum I have 5 Categories with IDs 1-5, and 15 Forums with IDs 2-16, and I get an error about a duplicate entry primary key with ID of 6. So each of the subcategories is supposed to have a parent_id of the agora category. It seems like the Category ID is not incrementing near line 81 for the next iteration, so it tries to create a new category with the same ID as the previous category.
So, basically at lines 46-49 you are counting how many categories there are and you assume they have the same id, but you should instead check for the largest ID. My forums got IDs from 2-6 for some reason, which broke everything.
Here is my code to replace lines 46-49, so that it reads the max id from the current categories and sets it as cat_mod_id (replace the code from line 46):
If you want to, you can also check if $rows is different than $max_id and then decide which one to use, however I think you really need to know the actual maximum category id since it is AUTO_INCREMENT as well, and having a duplicate key will break things!
--EDIT--
So here is my version of the code with my fix implemented:
$maxidquery = "SELECT id FROM jos_agora_categories ORDER BY id DESC LIMIT 0,1";
$resmax = mysql_query($maxidquery);
$resmaxid = mysql_fetch_array($resmax);
$maxid = $resmaxid['id'];
$cat_mod_id=$maxid+1;
--EDIT--
<?php
// Converter version 0.2.1 //////////////////////////////////////////////////////////////////////////////////////
$user = "";
$pass = "";
$db = "";
$sql = "
SELECT
echo $row->c.id;
echo "<br />";
echo $sql;
echo "<br />";
$sql = "
SELECT
echo $cat_mod_id;
echo "<br />";
echo "<br />";
echo $sql;
echo "<br />";
$cat_mod_id++;
echo "ARRAY:";
echo "<br />";
$sql = "
SELECT
t.id AS topic_id,
ORDER BY t.id ASC
echo "<br />";
echo $cat_id;
echo "<br />";
echo $sql;
echo "<br />";
$sql = "
SELECT
t.id AS topic_id,
ORDER BY t.id ASC
echo "<br />";
echo $cat_id;
echo "<br />";
echo $sql;
echo "<br />";
$sql = "
SELECT
ORDER BY p.id ASC
echo "<br />";
if ($cat_id != 0)
echo $cat_id;
echo "<br />";
echo $sql;
echo "<br />";
echo $sql2;
echo "<br />";
mysql_close();
Last edit: 13 years 3 months ago by silentz0r. Reason: Added full php code
