Solved Load Kunena Avatar
14 years 3 months ago - 14 years 3 months ago #130612 by betteryouthanme
With updating to latest Kunena 2.0, avatar integraton of my shoutbox doesnt work anymore. ( Ajax Shoutbox )
I just can guess that the misstake is somewhere here:
elseif($extension == 5) { require_once(JPATH_BASE.DS.'components'.DS.'com_kunena'.DS.'class.kunena.php'); $kunena_user = KunenaFactory::getUser($user->get('id')); $username = $kunena_user->getName(); $avatar = $kunena_user->getAvatarURL(); } return $avatar;
Maybe you can help here. If it is something more complicated i'll wait for reply of the shoutbox developer but he has not been around lately.
Two things fill the mind with ever new and increasing wonder and awe - the starry heavens above me and the moral law within me. Immanuel Kant
Last edit: 14 years 3 months ago by betteryouthanme.
14 years 3 months ago - 14 years 3 months ago #130619 by Jiminimonka
Replied by Jiminimonka on topic Load Kunena Avatar
I doubt that it is a bug in Kunena that is causing Shoutbox to not work, but it might be. Have you contacted the developer of that component with the error, so he can check if there is something in his code that needs updating?
Do you have an error log that shows the fault is with Kunena?
*** Moved to General Questions ***
Please read the FAQ.
Only one question per topic.
Last edit: 14 years 3 months ago by Jiminimonka.
14 years 3 months ago #130627 by betteryouthanme
Replied by betteryouthanme on topic Load Kunena Avatar
The code snippet is from the helper.php of the shoutbox.
With Kunena 1.7 everything worked well but you guys made too many changes :)
eg i dont even find the class.kunena.php?
There's no support atm for the shoutbox.
14 years 3 months ago - 14 years 3 months ago #130629 by Jiminimonka
So, Shoutbox needs updating. The changes to Kunena 2.0 were necessary to bring it up to date, fix multiple issues going back to Fireboard and allow it to be more extensible.
Have you looked for an alternative to this unsupported version of shoutbox?
extensions.joomla.org/extensions/communication/shoutbox
There are some commercial and non-commercial shoutboxes there, and some have been updated recently (July 2012).
14 years 3 months ago #130630 by TKtemp
Replied by TKtemp on topic Load Kunena Avatar
try with this code:
elseif($extension == 5) { $kunena_user = KunenaFactory::getUser($user->get('id')); $username = $kunena_user->getLink(); // Username/Name (depends of Kunena configuration) linked to profile page $user_avatar = $kunena_user->getAvatarImage('your-css-class', 100, 100); // get user avatar image, 100 is max-width and max-height $avatar = $kunena_user->getLink( $user_avatar ); // user avatar image linked to profile page } return $avatar;
The following user(s) said Thank You: betteryouthanme
14 years 3 months ago #130631 by Jiminimonka
As this is not a Support question I have moved the topic to General Questions.
